We are using a Jetson AGX Thor Developer Kit, and we are seeing intermittent unexpected reboots/shutdowns.
The issue does not seem to depend on workload. It can happen while the system is under heavy CPU/GPU/ROS workload, but it can also happen when the system is almost idle with no major processes running.
The system does not appear to perform a clean shutdown. The previous boot journal ends abruptly during normal application logs.
According to journalctl --list-boots, the previous boot ended unexpectedly, and the next boot started later. The last lines of the previous boot only show normal backend HTTP 200 responses such as:
[backend] INFO: "GET /status HTTP/1.1" 200 OK
[backend] INFO: "GET /timesync/diff HTTP/1.1" 200 OK
gpg-agent: can't connect to the daemon /usr/lib/gnupg/scdaemon
There is no clean shutdown sequence near the end of the previous boot. I do not see messages such as systemd stopping services, reboot target reached, poweroff, or a normal shutdown sequence.
I also checked the previous boot kernel journal:
journalctl -k -b -1 --no-pager -o short-monotonic
but it returned:
-- No entries --
So I could not find any previous-boot kernel panic, watchdog, thermal shutdown, or USB over-current messages from journalctl -k -b -1.
I then checked the current boot dmesg. There are some important messages:
EXT4-fs (nvme0n1p1): recovery complete
and:
systemd-journald[281]: File /var/log/journal/.../system.journal corrupted or uncleanly shut down, renaming and replacing.
This suggests that the previous shutdown was not clean.
I also checked pstore/ramoops. dmesg shows that ramoops is enabled:
pstore: Registered ramoops as persistent store backend
ramoops: using 0x200000@0x1fbf880000, ecc: 0
However, /sys/fs/pstore is empty after the reboot:
sudo ls -al /sys/fs/pstore
total 0
drwxr-x--- 2 root root 0 Nov 26 2025 .
drwxr-xr-x 9 root root 0 Jan 1 1970 ..
So I could not find any persistent kernel panic/oops log.
I also checked the PMC reset information:
cat /sys/devices/platform/bus@0/c800000.pmc/reset_reason
UNKNOWN
cat /sys/devices/platform/bus@0/c800000.pmc/reset_level
WARM
So it looks like the system experienced a warm reset rather than a clean software shutdown or a full cold power cycle. However, the reset reason is reported as UNKNOWN.
I also grepped dmesg for power/thermal/watchdog/reset related messages:
sudo dmesg -T | grep -Ei "thermal|throttle|over|voltage|power|pmic|brown|watchdog|wdt|shutdown|reset|panic|oops|error|fail"
The relevant lines include:
systemd[1]: Using hardware watchdog 'NVIDIA Tegra186 WDT', version 0, device /dev/watchdog0
systemd[1]: Watchdog running with a timeout of 2min.
I do not see a clear thermal shutdown, kernel panic, explicit watchdog reset, undervoltage, brownout, or PMIC shutdown message.
There are also some NVIDIA driver warnings/errors during boot, for example:
NVRM: devm_reset_control_get failed, err: -2
WARNING: CPU: 2 PID: 1402 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x16c
NVRM: rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff: Failure: Generic Error [NV_ERR_GENERIC]
These happen during the current boot, so I am not sure if they are related to the unexpected reset.
Summary of what we found:
The previous boot journal ends abruptly during normal application HTTP 200 logs.
There is no clean shutdown sequence.
journalctl -k -b -1has no previous boot kernel entries. -
/sys/fs/pstoreis empty. -
dmesg shows EXT4 recovery on the root filesystem.
dmesg shows that the previous system journal was corrupted or uncleanly shut down.
PMC reset information shows:
reset_reason: UNKNOWN reset_level: WARM -
I do not see clear evidence of kernel panic, thermal shutdown, explicit watchdog reset, undervoltage, brownout, or PMIC shutdown in the logs.
Questions:
- What does
reset_reason: UNKNOWNwithreset_level: WARMusually indicate on Jetson AGX Thor? - Is there any additional Jetson-specific log, register, or debugfs/sysfs entry that can explain an UNKNOWN/WARM reset?
- Could this indicate a watchdog reset, PMIC/power rail glitch, carrier-board-level reset, or firmware-level reset?
- Since pstore is empty, is there any other way to capture the cause of a sudden warm reset on Jetson Thor?
- Are the NVRM reset_control warnings or DCE RM control failure during boot known issues, or are they unrelated to the unexpected reset?
We can attach the following logs if needed:
- previous boot journal tail
- current dmesg
- dmesg power/reset/thermal filter output
- journalctl boot list
- PMC reset_reason/reset_level output
current_dmesg.txt (148.1 KB)
prev_boot_monotonic_end_300.txt (33.0 KB)
dmesg_power_filter.txt (18.2 KB)
and our power >>
