[jetson thor]烧录失败
每次烧录流程走到一半就失败了,提示无法获取设备特性 failed to get feature set ,请问是什么原因?
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(204)] : current totaltime in finding device online : 15
[flash_bsp_jetson-t264_die0]: [AdbFindDevice(210)] : found  the device :2U1TS94GO00000806040 online at the end of :20 seconds
[flash_bsp_jetson-t264_die0]: [AdbPush(334)] : Push file via ADB to target destination
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 push /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/wr_sh.sh  /tmp
cwd = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/flash_workspace/flash-images
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : [100%] /tmp/wr_sh.sh
/home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/wr_sh.sh: 1 file pushed. 0.1 MB/s (151 bytes in 0.002s)
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 push /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/nvdd  /tmp
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : [ 10%] /tmp/nvdd
[ 20%] /tmp/nvdd
[ 30%] /tmp/nvdd
[ 40%] /tmp/nvdd
[ 50%] /tmp/nvdd
[ 60%] /tmp/nvdd
[ 70%] /tmp/nvdd
[ 80%] /tmp/nvdd
[ 90%] /tmp/nvdd
[100%] /tmp/nvdd
/home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/nvdd: 1 file pushed. 32.1 MB/s (648144 bytes in 0.019s)
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 shell /tmp/wr_sh.sh chmod 766 /tmp/wr_sh.sh
EXITCODE=0
[flash_bsp_jetson-t264_die0]: [AdbShell(325)] : EXITCODE = 0
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 shell /tmp/wr_sh.sh chmod 766 /tmp/nvdd
EXITCODE=0
[flash_bsp_jetson-t264_die0]: [UpdatePVITFullFlashing(3021)] : Skipping PVIT update for bct in full flashing with unsigned customer data
[flash_bsp_jetson-t264_die0]: [ParallelFlashImages(2775)] : Working on 810c5b0000.spi
[flash_bsp_jetson-t264_die0]: [EraseQspi(1373)] : Erasing Qspi(/dev/block/810c5b0000.spi) .. Start 0 Size 0
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 shell /tmp/wr_sh.sh /tmp/nvdd --device /dev/block/810c5b0000.spi -E eoffset=0,esize=0
[flash_bsp_jetson-t264_die0]: [AdbShell(322)] :
[flash_bsp_jetson-t264_die0]: [EraseQspi(1380)] : Erase Qspi took 113.23959040641785
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1112)] : [810c5b0000.spi] Flashing for Partition bct
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1149)] : Remove previous instances of BCT
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1151)] : Copy partition BCT to destination
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1162)] : Make BCT size equal to 256KB by padding zeros at the end
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = dd if=/dev/zero of=die0_bctCopiesBlob.tmp seek=8192 count=253952 bs=1
[flash_bsp_jetson-t264_die0]: [executeShellCommand(163)] : 253952+0 records in
253952+0 records out
253952 bytes (254 kB, 248 KiB) copied, 0.116591 s, 2.2 MB/s
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1166)] : Copy resulting file to destination
[flash_bsp_jetson-t264_die0]: [FlashUsingADB(1172)] : Replicate BCT and append to destination. Repeated for size of the partition
[flash_bsp_jetson-t264_die0]: [SendFileUsingADB(667)] : Flashing Partition - bct of size 1048576 of File die0_bctCopiesBlob.tmp of size 786432
[flash_bsp_jetson-t264_die0]: [executeShellCommand(156)] : command = /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 push die0_bctCopiesBlob.tmp  /tmp
[flash_bsp_jetson-t264_die0]: [executeShellCommand(171)] : shell command -- /home/ubt/work/code/git/jetson_linux_r38.4.0/Linux_for_Tegra/unified_flash/out/bsp_images/tools/flashtools/flash/adb -s 2U1TS94GO00000806040 push die0_bctCopiesBlob.tmp  /tmp failed
[flash_bsp_jetson-t264_die0]: [executeShellCommand(173)] : Output: adb: error: failed to get feature set: device '2U1TS94GO00000806040' not found
[flash_bsp_jetson-t264_die0]: [executeShellCommand(175)] : Return code: 1
[flash_bsp_jetson-t264_die0]: [executeShellCommand(177)] : stdout: b"adb: error: failed to get feature set: device '2U1TS94GO00000806040' not found\n"
[flash_bsp_jetson-t264_die0]: [executeShellCommand(179)] : stderr: None
host-log_nvme_failed.zip (118.8 KB)
~0519
I have a few questions to help confirm the setup:
  • What is your host OS (Windows or Ubuntu)?
  • If you’re using Ubuntu, is it installed natively or running on a virtual machine?
  • Which version of Ubuntu are you using?
Also, could you pleaese try using a different flashing cable to cross check issues?
