make CUDA samples, builds fine, but there are many errors.
though many examples run.
what step did I miss?
are some of these examples not available on TK1? [1]
WARNING - CUDA OpenMP Libraries are not found
This CUDA Sample cannot be built without libgomp libraries.
This will be a dry-run of the Makefile.
For more information on how to set up your environment to build and run this
sample, please refer the CUDA Samples documentation and release notes
WARNING - No MPI compiler found.
CUDA Sample “simpleMPI” cannot be built without an MPI Compiler.
WARNING - libcuda.so not found, CUDA Driver is not installed. Please re-install the driver. <<<
[1]
WARNING - required GPU not available on this platform - waiving sample <<<
