Hi.
I develop CSI-2 stereo camera on Tegra K1 custom board.
Our hardware use below CSI-2 lane for using x4 lane.
camera1 : CSI_A_D[1:0]_N/P, CSI_B_D[1:0]_N/P ,CSI_A_CLK_N/P
camera2 : DSI_B_CLK_N/P , DSI_B_D[3:0]_N/P
I develop v4l2 driver refer to imx135_v4l2.c.
And I developed camera1 successfully.
Below command is to stream camera1.
gst-launch-1.0 v4l2src device="/dev/video0" ! 'video/x-bayer,format=bggr,width=1280,height=720' ! bayer2rgb ! videoconvert ! xvimagesink sync=false
But I can’t see camera2 stream to use same driver.
- Change Pad Control. arch/arm/boot/dts/tegra124-platforms/tegra124-jetson_tk1-pinmux-pm375-0000-c00-00.dtsi
- Add platform_device to "arch/arm/mach-tegra/board-ardbeg-sensors.c" same as camera1. Below is my added code.
- gst-launch output.
mipi_pad_ctrl_dsi_b {
nvidia,pins = "mipi_pad_ctrl_dsi_b";
<s>nvidia,function = "dsi_b";</s>
nvidia,function = "csi";
static struct tegra_io_dpd csic_io = {
.name = "DSI",
.io_dpd_reg_index = 0,
.io_dpd_bit = 2,
static struct tegra_io_dpd csid_io = {
.name = "DISB",
.io_dpd_reg_index = 1,
.io_dpd_bit = 7,
// Same code at v4l2 driver .s_power
static int ardbeg_ap0101_power(struct device *dev, int enable)
if(enable) {
tegra_io_dpd_disable(&csic_io); // Is it correct to use CSI_C??
tegra_io_dpd_disable(&csid_io); // Is it correct to use CSI_D??
} else {
tegra_io_dpd_enable(&csic_io);
tegra_io_dpd_enable(&csid_io);
return 0;
static struct i2c_board_info ardbeg_ap0101_camera_i2c_device_1 = {
I2C_BOARD_INFO("ap0101at", 0x72),
.platform_data = &ardbeg_ap0101_data,
static struct tegra_camera_platform_data ardbeg_ap0101_camera_platform_data_1 = {
.flip_v = 0,
.flip_h = 0,
.port = TEGRA_CAMERA_PORT_CSI_B,
.lanes = 4,
.continuous_clk = 1,
static struct soc_camera_link ap0101_iclink_1 = {
.bus_id = 1, /* This must match the .id of tegra_vi01_device */
.board_info = &ardbeg_ap0101_camera_i2c_device_1,
.module_name = "ap0101at",
.i2c_adapter_id = 0,
.power = ardbeg_ap0101_power,
.priv = &ardbeg_ap0101_camera_platform_data_1,
static struct platform_device ardbeg_ap0101_soc_camera_device_1 = {
.name = "soc-camera-pdrv",
.id = 2,
.dev = {
.platform_data = &ap0101_iclink_1,
[ 76.684125] MIPI calibration for CSI is done
[ 76.887753] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 1, err = -11
[ 76.900737] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 76.905679] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 76.915782] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 76.925924] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 76.937733] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 76.944773] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 76.952677] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 76.962827] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 76.974731] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 76.981439] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 76.987117] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 76.992079] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 77.056709] ap0101at_set_output:1038] success!!! output enable change config
[ 77.068738] ap0101at_s_stream:1252] success to set up output enable!!!
[ 77.125469] ap0101at 0-0072: ap0101at_s_stream:1258] OUT-----
[ 77.196959] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 2, err = -11
[ 77.205098] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 77.210501] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 77.215712] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 77.220547] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 77.225365] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 77.231069] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 77.235976] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 77.240917] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 77.245736] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 77.251473] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 77.257172] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 77.262107] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 77.466939] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 3, err = -11
[ 77.475057] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 77.480250] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 77.485149] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 77.489885] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 77.494774] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 77.499678] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 77.504551] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 77.509360] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 77.514282] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 77.519871] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 77.525649] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 77.530586] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 77.734982] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 4, err = -11
[ 77.742853] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 77.748163] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 77.753036] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 77.757777] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 77.762591] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 77.767653] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 77.772473] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 77.777293] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 77.782173] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 77.787889] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 77.793641] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 77.798536] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 78.002923] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 5, err = -11
[ 78.010008] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 78.014783] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 78.019664] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 78.024468] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 78.029300] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 78.034033] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 78.039083] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 78.043900] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 78.048806] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 78.054463] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 78.060156] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 78.065206] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 78.269841] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 6, err = -11
[ 78.279323] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 78.286739] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 78.292586] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 78.297754] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 78.303120] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 78.309292] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 78.316386] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 78.321514] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 78.326431] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 78.332365] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 78.338156] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 78.344269] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 78.550850] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 7, err = -11
[ 78.558905] TEGRA_CSI_DEBUG_COUNTER_0 0x00000000
[ 78.564471] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000000
[ 78.570273] TEGRA_CSI_CSI_CILA_STATUS 0x00000000
[ 78.575419] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 78.580871] TEGRA_CSI_CSI_CILB_STATUS 0x00000000
[ 78.585616] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000000
[ 78.590460] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 78.595345] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 78.600382] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 78.606238] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 78.611851] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 78.616912] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 78.822007] vi vi.1: CSI_B/CSI_C syncpt timeout, syncpt = 8, err = -11
- Is is correct way? To use CSI_C/D_D(DSI_B_D[3:0]) set csic_io, csid_io I necessarily use DSIB(APBDEV_PMC_IO_DPD2_REQ_0:7bit) and DSI(APBDEV_PMC_IO_DPD_REQ_0 :2bit). Because CSIC and CSID(APBDEV_PMC_IO_DPD2_REQ_0:10,11bit) is defunct.
- What is exactly means .id member of struct platform_device?
- Can I implementable CSI-B(x4, DSI) In r21.4 BSP?
Thank you for reading for my poor English skill.
Please reply my question.
Best regard.
