Hi All,
I recently purchased the TK1 Dev Kit, and I have been testing various benchmarks to see if we can use this hardware in a product.
I ran “openssl speed” to get some basic benchmark data before trying to setup/run parallel activities.
However, I ran into a problem when it came to sing/verify ecdsa’s. I kept seeing “ECDSA verify failure”. I’ve never seen that before when running this benchmark. I’ve copied the relevant benchmark output below.
Has anyone else seen this issue using the Jetson TK1 DevKit? Could it be inherent to the customized Ubuntu, or maybe I’m just doing something wrong?
Doing 160 bit sign ecdsa's for 10s: 53825 160 bit ECDSA signs in 9.97s
Doing 160 bit verify ecdsa's for 10s: 14772 160 bit ECDSA verify in 9.99s
Doing 192 bit sign ecdsa's for 10s: 43248 192 bit ECDSA signs in 9.98s
Doing 192 bit verify ecdsa's for 10s: 11186 192 bit ECDSA verify in 10.00s
Doing 224 bit sign ecdsa's for 10s: 34104 224 bit ECDSA signs in 9.99s
Doing 224 bit verify ecdsa's for 10s: 8361 224 bit ECDSA verify in 10.00s
Doing 256 bit sign ecdsa's for 10s: 27963 256 bit ECDSA signs in 9.98s
Doing 256 bit verify ecdsa's for 10s: 6556 256 bit ECDSA verify in 10.00s
Doing 384 bit sign ecdsa's for 10s: 12796 384 bit ECDSA signs in 9.99s
Doing 384 bit verify ecdsa's for 10s: 2659 384 bit ECDSA verify in 10.00s
Doing 521 bit sign ecdsa's for 10s: 5687 521 bit ECDSA signs in 10.00s
Doing 521 bit verify ecdsa's for 10s: 1052 521 bit ECDSA verify in 10.00s
Doing 163 bit sign ecdsa's for 10s: 15744 163 bit ECDSA signs in 9.99s
Doing 163 bit verify ecdsa's for 10s: 5335 163 bit ECDSA verify in 10.00s
Doing 233 bit sign ecdsa's for 10s: 7573 233 bit ECDSA signs in 9.99s
Doing 233 bit verify ecdsa's for 10s: ECDSA verify failure
1 233 bit ECDSA verify in 10.00s
Doing 283 bit sign ecdsa's for 10s: 5031 283 bit ECDSA signs in 10.00s
Doing 283 bit verify ecdsa's for 10s: 1580 283 bit ECDSA verify in 10.00s
Doing 409 bit sign ecdsa's for 10s: 1778 409 bit ECDSA signs in 10.00s
ECDSA verify failure. No ECDSA verify will be done.
Doing 571 bit sign ecdsa's for 10s: 799 571 bit ECDSA signs in 10.01s
Doing 571 bit verify ecdsa's for 10s: 321 571 bit ECDSA verify in 10.01s
Doing 163 bit sign ecdsa's for 10s: 15819 163 bit ECDSA signs in 9.99s
Doing 163 bit verify ecdsa's for 10s: ECDSA verify failure
1 163 bit ECDSA verify in 10.00s
Doing 233 bit sign ecdsa's for 10s: 7624 233 bit ECDSA signs in 9.99s
Doing 233 bit verify ecdsa's for 10s: 2674 233 bit ECDSA verify in 10.00s
Doing 283 bit sign ecdsa's for 10s: 5033 283 bit ECDSA signs in 10.00s
Doing 283 bit verify ecdsa's for 10s: ECDSA verify failure
1 283 bit ECDSA verify in 10.00s
Doing 409 bit sign ecdsa's for 10s: 1775 409 bit ECDSA signs in 10.00s
Doing 409 bit verify ecdsa's for 10s: 661 409 bit ECDSA verify in 10.01s
Doing 571 bit sign ecdsa's for 10s: 800 571 bit ECDSA signs in 10.00s
Doing 571 bit verify ecdsa's for 10s: 278 571 bit ECDSA verify in 10.02s
Here’s the Summary:
sign verify sign/s verify/s
160 bit ecdsa (secp160r1) 0.0002s 0.0007s 5398.7 1478.7
192 bit ecdsa (nistp192) 0.0002s 0.0009s 4333.5 1118.6
224 bit ecdsa (nistp224) 0.0003s 0.0012s 3413.8 836.1
256 bit ecdsa (nistp256) 0.0004s 0.0015s 2801.9 655.6
384 bit ecdsa (nistp384) 0.0008s 0.0038s 1280.9 265.9
521 bit ecdsa (nistp521) 0.0018s 0.0095s 568.7 105.2
163 bit ecdsa (nistk163) 0.0006s 0.0019s 1576.0 533.5
233 bit ecdsa (nistk233) 0.0013s 10.0000s 758.1 0.1
283 bit ecdsa (nistk283) 0.0020s 0.0063s 503.1 158.0
571 bit ecdsa (nistk571) 0.0125s 0.0312s 79.8 32.1
163 bit ecdsa (nistb163) 0.0006s 10.0000s 1583.5 0.1
233 bit ecdsa (nistb233) 0.0013s 0.0037s 763.2 267.4
283 bit ecdsa (nistb283) 0.0020s 10.0000s 503.3 0.1
409 bit ecdsa (nistb409) 0.0056s 0.0151s 177.5 66.0
571 bit ecdsa (nistb571) 0.0125s 0.0360s 80.0 27.7
