I have seen a problem in TK1 devices, while problem occurs, device will go into black screen, I have checked kernel log, there are some gpu errors in kernel log like below, is there anyone can help me in this problem?
[ 369.240577] tegra-i2c tegra12-i2c.4: — register dump for debugging ----
[ 369.240581] tegra-i2c tegra12-i2c.4: I2C_CNFG - 0x2c00
[ 369.240584] tegra-i2c tegra12-i2c.4: I2C_PACKET_TRANSFER_STATUS - 0x1ff0001
[ 369.240586] tegra-i2c tegra12-i2c.4: I2C_FIFO_CONTROL - 0xe0
[ 369.240589] tegra-i2c tegra12-i2c.4: I2C_FIFO_STATUS - 0x800080
[ 369.240591] tegra-i2c tegra12-i2c.4: I2C_INT_MASK - 0xec
[ 369.240594] tegra-i2c tegra12-i2c.4: I2C_INT_STATUS - 0xc2
[ 369.240596] tegra-i2c tegra12-i2c.4: msg->len - 2
[ 369.240598] tegra-i2c tegra12-i2c.4: is_msg_write - 1
[ 369.240600] tegra-i2c tegra12-i2c.4: buf_remaining - 0
[ 369.240607] tegra-i2c tegra12-i2c.4: i2c transfer timed out, addr 0x0040, data 0x4d
[ 369.240653] ------------[ cut here ]------------
[ 369.240662] WARNING: at /home/kevin/jtk1-android-l-open-source/kernel/arch/arm/mach-tegra/powergate-t12x.c:507 tegra12x_unpowergate_partition+0x1b4/0x288()
[ 369.240669] Could not Un-Railgate 1
[ 369.240680] Modules linked in: mbt8897 opzoon_pwm wg_tegra mac80211 sd8xxx mlan
[ 369.240684] CPU: 2 PID: 1492 Comm: RenderThread Not tainted 3.10.33-svn558 #25
[ 369.240694] [] (unwind_backtrace+0x0/0x13c) from [] (show_stack+0x18/0x1c)
[ 369.240702] [] (show_stack+0x18/0x1c) from [] (warn_slowpath_common+0x5c/0x74)
[ 369.240708] [] (warn_slowpath_common+0x5c/0x74) from [] (warn_slowpath_fmt+0x38/0x48)
[ 369.240713] [] (warn_slowpath_fmt+0x38/0x48) from [] (tegra12x_unpowergate_partition+0x1b4/0x288)
[ 369.240718] [] (tegra12x_unpowergate_partition+0x1b4/0x288) from [] (tegra_unpowergate_partition+0x68/0x10c)
[ 369.240726] [] (tegra_unpowergate_partition+0x68/0x10c) from [] (gk20a_pm_unrailgate+0x50/0x64)
[ 369.240733] [] (gk20a_pm_unrailgate+0x50/0x64) from [] (__pm_genpd_poweron+0x234/0x2b0)
[ 369.240739] [] (__pm_genpd_poweron+0x234/0x2b0) from [] (pm_genpd_runtime_resume+0xa4/0x2f0)
[ 369.240745] [] (pm_genpd_runtime_resume+0xa4/0x2f0) from [] (__rpm_callback+0x34/0x68)
[ 369.240750] [] (__rpm_callback+0x34/0x68) from [] (rpm_callback+0x28/0x7c)
[ 369.240754] [] (rpm_callback+0x28/0x7c) from [] (rpm_resume+0x3dc/0x6a4)
[ 369.240758] [] (rpm_resume+0x3dc/0x6a4) from [] (__pm_runtime_resume+0x50/0x68)
[ 369.240764] [] (__pm_runtime_resume+0x50/0x68) from [] (gk20a_busy+0x38/0xa4)
[ 369.240769] [] (gk20a_busy+0x38/0xa4) from [] (gk20a_submit_channel_gpfifo+0x94/0xa70)
[ 369.240773] [] (gk20a_submit_channel_gpfifo+0x94/0xa70) from [] (gk20a_channel_ioctl+0x604/0xf50)
[ 369.240778] [] (gk20a_channel_ioctl+0x604/0xf50) from [] (do_vfs_ioctl+0x408/0x5d4)
[ 369.240783] [] (do_vfs_ioctl+0x408/0x5d4) from [] (SyS_ioctl+0x78/0x88)
[ 369.240788] [] (SyS_ioctl+0x78/0x88) from [] (ret_fast_syscall+0x0/0x30)
[ 369.240790] —[ end trace fcf97d77c66b2587 ]—
[ 369.240811] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.241056] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.241113] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.241135] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.241160] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.242633] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.242692] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 369.243081] gk20a gk20a.0: gk20a_submit_channel_gpfifo: failed to host gk20a to submit gpfifo
[ 380.247740] gk20a gk20a.0: gk20a_channel_ioctl: failed to host gk20a for ioctl cmd: 0x8008486d
[ 380.256362] gk20a gk20a.0: gk20a_channel_release: failed to release channel 1
[ 384.626602] gk20a gk20a.0: gk20a_channel_ioctl: failed to host gk20a for ioctl cmd: 0x8008486d
[ 384.635252] gk20a gk20a.0: gk20a_channel_release: failed to release channel 4
[ 387.088652] gk20a gk20a.0: gk20a_channel_ioctl: failed to host gk20a for ioctl cmd: 0x8008486d
[ 387.097263] gk20a gk20a.0: gk20a_channel_release: failed to release channel 9
[ 387.327317] gk20a gk20a.0: gk20a_channel_release: failed to release channel 0
[ 387.336396] gk20a gk20a.0: gk20a_channel_release: failed to release channel 2
[ 387.557740] gk20a gk20a.0: __gk20a_channel_open: failed to power on, -22
[ 387.625805] gk20a gk20a.0: gk20a_channel_release: failed to release channel 8
[ 387.625869] gk20a gk20a.0: gk20a_channel_release: failed to release channel 6
[ 387.625893] gk20a gk20a.0: gk20a_channel_release: failed to release channel 10
[ 387.625988] gk20a gk20a.0: gk20a_channel_release: failed to release channel 5
[ 387.697287] gk20a gk20a.0: gk20a_channel_release: failed to release channel 7
[ 387.706431] gk20a gk20a.0: gk20a_channel_release: failed to release channel 3
