trying again to flash the board with the above ppt.img work around but it now fails as follows:
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x340010017408c1431c0000000fff0280
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017408c1431c0000000fff0280
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59637/59637 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader -- load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin
- 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 1 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
creating partition: BCT
creating partition: PPT
creating partition: PT
creating partition: EBT
creating partition: LNX
creating partition: SOS
creating partition: NVC
creating partition: MPB
creating partition: MBP
creating partition: GP1
creating partition: APP
creating partition: DTB
creating partition: EFI
creating partition: USP
creating partition: TP1
creating partition: TP2
creating partition: TP3
creating partition: WB0
creating partition: UDA
creating partition: GPT
sending file: ppt.img
ppt.img sent successfully
sending file: u-boot.bin
- 440016/440016 bytes sent
u-boot.bin sent successfully
sending file: system.img
| 2372383172/2372383172 bytes sent
system.img sent successfully
failed to verify partition
command failure/warning: create failed (bad data)
The serial console output is, I verified that no return chars are sent back frorm minicom while being programmed:
[0000.000] [TegraBoot] (version UNDEF_BUILD)
[0000.004] Reset reason: power on reset
[0000.007] Processing in recovery mode
[0000.011] Established communication link with host
[0001.128] Downloaded bct successfully
[0001.132] No Battery Present
[0001.136] Sdram initialization is successful
[0001.147] Downloaded DTB successfully
[0001.174] No Battery Present
[0001.244] Downloaded bootloader successfully
[0001.248] CPU-bootloader entry address: 0x83d88000
[0001.253] BoardId: 375
[0001.255] Vpr Carveout Base=0x0f4600000 Size=0x00ba00000
[0001.260] Tsec Carveout Base=0x0f2600000 Size=0x002000000
[0001.265] Lp0 Carveout Base=0x0f25ff000 Size=0x000001000
[0001.270] Xusb Carveout Base=0x0f2300000 Size=0x000200000
[0001.275] Platform-DebugCarveout: 0
[0001.303] CPU power rail is up
[0001.305] Performing RAM repair
[0001.308] CPU clock init successful
[0001.312] Starting CPU & Halting co-processor
NVRM Initialized shmoo database
NVRM CLOCKS: PLLX0: 696000 Khz
NVRM CLOCKS: PLLM0: 924000 Khz
NVRM CLOCKS: PLLC0: 0 Khz
NVRM CLOCKS: PLLP0: 408000 Khz
NVRM CLOCKS: PLLA0: 11289 Khz
NVRM CLOCKS: CPU: 696000 Khz
NVRM CLOCKS: AVP: 48000 Khz
NVRM CLOCKS: System Bus: 48000 Khz
NVRM CLOCKS: Memory Controller: 924000
NVRM CLOCKS: External Memory Controller: 924000
EEPROM instance-5: No slave at this instance.
EEPROM instance-0: No slave at this instance.
EEPROM instance-0: Querying board info from BCT.
EEPROM instance-0: No board info available for this instance in BCT.
EEPROM instance-1: No slave at this instance.
EEPROM instance-1: Querying board info from BCT.
EEPROM instance-1: Board info present in BCT is invalid.
EEPROM instance-2: No slave at this instance.
EEPROM instance-2: Querying board info from BCT.
EEPROM instance-2: No board info available for this instance in BCT.
EEPROM instance-3: No slave at this instance.
EEPROM instance-3: Querying board info from BCT.
EEPROM instance-3: No board info available for this instance in BCT.
EEPROM instance-4: No slave at this instance.
EEPROM instance-4: Querying board info from BCT.
EEPROM instance-4: Board info present in BCT is invalid.
EEPROM instance-5: Querying board info from BCT.
EEPROM instance-5: Board info present in BCT is invalid.
EEPROM instance-6: BoardInfo: 0x0001:0x0007:0375:0000:03:E:00:0xff:0xff:0xff:0xff:0xff:0xff
EEPROM instance-7: No slave at this instance.
EEPROM instance-7: Querying board info from BCT.
EEPROM instance-7: No board info available for this instance in BCT.
Final BoardID: proc: 375 and pmu 375
ADJUSTED CLOCKS:
MC clock is set to 924000 KHz
EMC clock is set to 924000 KHz (DDR clock is at 924000 KHz)
PLLX0 clock is set to 696000 KHz
PLLC0 clock is set to 0 KHz
CPU clock is set to 696000 KHz
System and AVP clock is set to 48000 KHz
GraphicsHost clock is set to 163200 KHz
MSENC clock is set to 92400 KHz
Vde clock is set to 204000 KHz
Bootloader-Cpu Init at (time stamp): 32989271 us
Pinmux changes applied in kernel way
[bootloader] (version UNDEF_BUILD)
Platform Pre Boot configuration...
NvDdkUsbhBlockDevInit..
Initializing Display
The proc BoardInfo: 0x0177:0x0000:0x03:0x45:0x00
This Pmu Module is not present.
The best display mode is 2560x1600/60Hz, pclk: 268627Khz
DSI PAD calibration done
Entering NvFlash recovery mode / Nv3p Server
Nv3pServer Version 4.13.0000
***: DecodeCSD:
: readBlkBits=9, readBlkSize=512 Bytes
: nSectors=(CSIZE+1)*(2**(CSizeMult+2))=4096 * 512 = 2097152 Sectors
: writeBlkBits=9, writeBlkSize=512 Bytes
: ERASE_GRP_SIZE=31, ERASE_GRP_MULT=31
: EraseGrpSize=(31+1)*(31+1)=1024 Sectors (524288 Bytes)
: WPGrpSize=31744 Sectors (16252928 Bytes)
***: ReadExtCSD:
: overriding USER Sectors = 30777344 Sectors
: keep CSD EraseGrpSize = 1024 Sectors (524288 Bytes)
: keep CSD WPGrpSize = 31744 wBlks (16252928 Bytes)
: BootPartSize = 4194304 Bytes (8192 Sectors)
***: SetBlockSize to 512 Bytes SKIPPED because CMD16 is illegal for DDR50...
***: SdGetDevInfo: PagesPerBlock = 32 pages (256 Sectors)
***: SdGetDevInfo: TotSecs=TotBlk(120288)*PgPerBlk(32)*SecsPerPg(8)=30793728
Region=1 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=2 SD Erase start 512B-sector=0,512B-sector-num=8192
Region=0 SD Erase start 512B-sector=0,512B-sector-num=30777344
SD Alloc Partid=2, start sector=0,num=2048
SD Alloc Partid=3, start sector=2048,num=512
SD Alloc Partid=4, start sector=2560,num=512
SD Alloc Partid=5, start sector=3072,num=1024
SD Alloc Partid=6, start sector=4096,num=4096
SD Alloc Partid=7, start sector=8192,num=1536
SD Alloc Partid=8, start sector=9728,num=512
SD Alloc Partid=9, start sector=10240,num=1536
SD Alloc Partid=10, start sector=11776,num=1536
SD Alloc Partid=11, start sector=13312,num=512
SD Alloc Partid=12, start sector=13824,num=3670016
SD Alloc Partid=13, start sector=3683840,num=1024
SD Alloc Partid=14, start sector=3684864,num=16384
SD Alloc Partid=15, start sector=3701248,num=1024
SD Alloc Partid=16, start sector=3702272,num=1024
SD Alloc Partid=17, start sector=3703296,num=1024
SD Alloc Partid=18, start sector=3704320,num=1024
SD Alloc Partid=19, start sector=3705344,num=512
SD Alloc Partid=20, start sector=3705856,num=142848
SD Alloc Partid=21, start sector=3848704,num=512
Region=0 SD Erase start 512B-sector=4096,512B-sector-num=4096
Start Downloading PPT
End Downloading PPT
Time taken to download partition: 4 ms
Start Downloading EBT
Parallel write enabled
End Downloading EBT
Time taken to download partition: 190 ms
Start Downloading APP
WriterThread: Exiting
DownloadPartition failed. NvError 10 NvStatus 0
Time taken to download partition: 185397 ms
If I repeat the .nvflash command, sometimes it seems to get further than others, this is the ouput of an aditioan l attempt, it seems to get past sys.img but fails on the next part.
bootloader status: fatal failure to read / write to mass storage (code: 9) message: flags: 0
Is there any additional information I can provide to help understand this?
