i tried to find out if the 4MB SPI boot flash is a NOR-Flash.
The only information i got, from the nvidia schematics, was the chip type used on the board. It should be a winbond W25Q32DW.
After a little bit of research, the used chip should be a serial-nor-flash.
Is that right? Does the Board use that winbond chip? And is that chip an NOR-Flash type?
It should be a serial-nor-flash
W25Q32DW datasheet doesn’t mention flash type though
https://www.winbond.com/NR/rdonlyres/D35D5D04-4CE9-46A1-8950-AEA573045507/0/W25Q32DW.pdf
Winbond site mention NOR flash lineup
http://www.winbond.com/hq/enu/aboutwinbond/companyprofile/overview.htm
It’s most likely to be NOR flash type
