Hi guys,
I'm using Jetson TK1 board with original Tegra software package.
The kernel frequently reports the message that:
[ 643.916659] Timed out wiating for pll_m lock bit ([0x90] = 0x44004d01)
[ 644.264920] Timed out wiating for pll_m lock bit ([0x90] = 0x44004d01)
[ 644.665915] Timed out wiating for pll_m lock bit ([0x90] = 0x44004d01)
[ 644.967634] Timed out wiating for pll_m lock bit ([0x90] = 0x44004d01)
It seems that this issue doesn't harm the system yet.
I'm not sure whether 0x44004d01 is a virtual address or a physical address. I look the address up in Tk1's spec. However, it shows that 0x44004d01 is unused in Physical address space.
The Tegra Linux Driver Package version in use is 21.1.0_armhf.
Could you please have a look at this issue?
Thank you.
Best regards,
David
