This VM from “Eltechs” called “ExaGear Desktop” should work on the Jetson Tk1 with much better performance than qemu. I already pre-ordered a copy and will write a review once it works on my Jetson Tk1.
It might be needed to re-compile the current L4T kernel with slightly different
configuration options to get the VM running.
With grinch 19.3.6 it is possible to use Exagear x86 vm in the following way:
-start a shell in the guest image (currently Ubuntu 12.04 LTS x86-32)
-install required ubuntu 12.04LTS x86 packages via apt-get install
run command line or GUI based applications without additional configuration
( I tried firefox_x86 )
install wine
run Windows applications
( I tried Windows Word viewer)
Next time I will have a look on multimedia support and performance in the vm world.
The x86 steam Client when run in the VM shows the following error message:
Video Driver Problem
Your system is running older proprietary nVidia video drivers. Steam requires driver version 304.22 or higher.
It also says:
OpenGlx is not using direct rendering
Hey Nvidia - can you fix this ?
Any known workaround ?
