Hey,
after using u-boot to test my custom kernel I have encountered a weird problem.
The board sometimes (like 1 out of 10-15 times) will not boot correctly.
It gets stuck here:
MSELECT error detected! status=0x100
[ 5.786767] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 5.807609] ------------[ cut here ]------------
[ 5.817829] kernel BUG at /dvs/git/dirty/git-master_linux/kernel/drivers/platform/tegra/hier_ictlr/hier_ictlr.c:54!
[ 5.834037] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[ 5.845660] Modules linked in:
[ 5.854539] CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 3.10.40-gdacac96 #1
[ 5.867444] Workqueue: kmmcd mmc_rescan
[ 5.877163] task: ee0a7080 ti: ee106000 task.ti: ee106000
[ 5.888485] PC is at tegra_hier_ictlr_irq_handler+0x38/0x40
[ 5.899928] LR is at tegra_hier_ictlr_irq_handler+0x38/0x40
[ 5.911263] pc : [<c0622e8c>] lr : [<c0622e8c>] psr: 20000193
[ 5.911263] sp : ee107ba8 ip : 00000000 fp : c0d13d98
[ 5.934318] r10: 00000000 r9 : 00000000 r8 : ee106000
[ 5.945336] r7 : ee107c48 r6 : 0000009f r5 : c0bd5910 r4 : ed0c06c0
[ 5.957663] r3 : 00000002 r2 : c0c99f70 r1 : 20000193 r0 : 00000024
[ 5.969979] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 5.983208] Control: 10c5387d Table: 8000406a DAC: 00000015
[ 5.994810]
[ 5.994810] PC: 0xc0622e0c:
[ 6.010660] 2e0c ebf80a42 e1a01004 e3a02000 e1a00005 ebf819ac e1a00004 e3a01000 ebf81a34
[ 6.024928] 2e2c e1a00004 e59f1008 e3a02000 e8bd4070 eaf81960 c0cf3098 e92d4000 e8bd4000
[ 6.039247] 2e4c e3a00004 e12fff1e e92d4008 e92d4000 e8bd4000 e1a00001 ebf7e1c5 e590300c
[ 6.053564] 2e6c e5931060 f57ff04f e3510000 1a000001 e3a00001 e8bd8008 e59f0004 eb07bd64
[ 6.067954] 2e8c e7f001f2 c0a97fec e92d40f8 e92d4000 e8bd4000 e1a06001 e1a07002 e3a01c02
[ 6.082417] 2eac e3a02000 e1a04000 ebf7e9b0 e2501000 0a000012 e2845010 e1a00005 ebf28b09
[ 6.096948] 2ecc e3500000 e5860000 0a000016 e3a01c02 e1a00004 e3a02001 ebf7e9a4 e2501000
[ 6.111540] 2eec 0a00000b e1a00005 ebf28afe e3500000 e5870000 0a000010 e3a00000 e8bd80f8
[ 6.126197]
I went back to using my original image and still had the problem with the original kernel from the L4T 21.4.
After trying the same kernel with fastboot the issue did not persist. At least I was not able to reproduce it.
My u-boot kernel commandline is unmodified as follows:
console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt
While the fastboot commandline looks like this:
fbcon=map:1 tegraid=40.1.1.0.0 mem=1862M@2048M memtype=255 vpr=151M@3945M tsec=32M@3913M otf_key=20a408444a4cd8f593bb2b3bdd6073d6 ddr_die=2048M@2048M section=256M commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@10 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,3 console=tty1 sku_override=0 usbcore.old_scheme_first=1 lp0_vec=2080@0xf46ff000 tegra_fbmem=32899072@0xad012000 core_edp_mv=1150 core_edp_ma=4000 pmuboard=0x0177:0x0000:0x03:0x45:0x00 power_supply=Adapter board_info=0x0177:0x0000:0x03:0x45:0x00 root=/dev/mmcblk0p1 rw rootwait tegraboot=sdmmc gpt gpt_sector=94207 modem_id=0 watchdog=disable android.kerneltype=normal
I have noticed that the 2015MB ram used in the u-boot options are split into mem=1862M and and vpr=151M for fastboot. Could there be any issue? I have seen other quotes of u-boot command lines using just 1862M ram.
Side info: I changed my partition table to use one system partition of 11580MiB and one additional 3000MiB partition to store my application data.
My question is, what could be causing the random boot fails with the u-boot bootloader?
Additionally I wonder if anyone can tell me what the “vpr=xxMB” options will do?
Using "IGNOREFASTBOOTCMDLINE=“vpr=151M@3945M” and
CMDLINE_ADD=“fbcon=map:1 usbcore.usbfs_memory_mb=1000 mem=2015M@2048M”;
did result in a not booting system with fastboot.
I’d like to at least have the 1960MB ram in fastboot if i have to use it to make sure that the system always boots.
