Our jetson-tk1 project encounters a MSELECT error crashing when debugging PCIE: the project uses both LVDS and PCIE, the jetson-tk1 board communicates with a FPGA board through mini-PCIE interface. The PCIE works properly, but it crashed after working for a while (sometimes for 5 minutes, sometimes for 2 hours?).
It seems that the PCIE timeouts before crash (no PCIE data log output for a while before crash output), the debug port prints as below:
[10:12:47]MSELECT error detected! status=0x4
[10:12:47]------------[ cut here ]------------
[10:12:47][ 106.381433] ------------[ cut here ]------------
[10:12:47]kernel BUG at /home/evan/Jetson_TK1/JetPackTK1-1.2/Linux_for_Tegra/sources/kernel_source/drivers/platform/tegra/hier_ictlr/hier_ictlr.c:59!
[10:12:47][ 106.399356] kernel BUG at /home/evan/Jetson_TK1/JetPackTK1-1.2/Linux_for_Tegra/sources/kernel_source/drivers/platform/tegra/hier_ictlr/hier_ictlr.c:59!
[10:12:47]Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[10:12:47][ 106.418226] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[10:12:47]Modules linked in:[ 106.425665] Modules linked in:
[10:12:47]
[10:12:47]CPU: 0 PID: 2158 Comm: pcie_preview_02 Tainted: G W 3.10.40-gdacac96-dirty #86
I debuged and the trigger code locate at:
at the ISR of hier_ictlr, it triggers coredump at once when MSELECT error occurs:
static irqreturn_t tegra_hier_ictlr_irq_handler(int irq, void *data)
status = readl(ictlr->mselect_base + MSELECT_ERROR_STATUS_0);
if (status != 0) {
printk(KERN_ERR"MSELECT error detected! status=0x%x\n",
(unsigned int)status);
<b>BUG(); // <--- trigger here</b>
After searched in TegraK1_TRM, I can’t find the detail information about status of MSELECT, and I don’t know the meanings of “status=0x4” of above, and the information of MSELECT is lacking in the manual, it is difficult to understand the machanism of MSELECT from the manual.
So does anbody know what the “MSELECT error” above meanings? or What should to do to debug above problems?
Any help is very appreciated!
BTW, after debugging for days, it is found that the probability of MSELECT error is reduced rapidly after turn-off the suspending function of system (In Ubuntu desktop, “All Settings” → “Brightness & Lock” → “Turn Screen off when inactive for xx minute”, change it to “Never”), but it is still there, occurs with small probability.
Regards
