I’m testing custom driver in L4T24.2.1
This driver and sensor are already tested in 24.2 and there are no issues.
I have tested 2 resolutions in 24.2.1
->1936 x 1101 is OK
->3872 x 1101 gives streaming error
Both resolutions worked in L4T24.2
Issue details
Resolution : 3872 x 1101
Error : [VI_CSI_4_ERROR_STATUS_0] (phys addr:0x54080584) 0x00000001
TRM says this is LINE_WIDTH_SHORT_ERROR
Behavior : Streaming gives distorted and blinking pixels
Anything additional modification needed when driver is ported from 24.2 → 24.2.1 ?
Thanks in advance,
Mathews
@Mats
Does the below command can get raw data well.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1936 ,height=1101 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3872,height=1101 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
kayccc
August 17, 2017, 5:41am
3
Hi mats_X1,
Have you clarified and resolved the problem?
Any result can be shared?
Hi ShaneCCC and kayccc,
Thank You for your replies.
I can’t use v4l2-ctl tool since my application performs sensor configuration(not by driver).
Regards,
Mathews
@mats
What’s your test command/APP?
From the log is semms the width is incorrect as sensor output. I have no idea why the 24.2 didn’t have problem. However you can check the sensor spec or vendor to try other similar size setting to try.
