Jetson TX1 Dev Kit - Unmarked dimensions on assembly drawing
Greetings all,
I am working on developing a camera module for the tx1 and could not locate the horizontal offsets of the 5 mounting holes marked ‘C’ on the assembly drawing. Specifically, I was hoping someone could direct me to a pdf containing the information pertaining to these offsets and the relative position of the Samtech camera expansion port to these mounting holes.
Regards,
adoucette@dal
These horizontal dimensions are missed in assembly drawing, will be updated in next version.
You can get the dimensions by layout file. In Cadence, choose Display -> Color/Visibility -> Board Geometry, then turn on Nv_Dimensions_Top.
