Stupig
April 25, 2016, 8:35am
#1
I ran some quick and rough video latency tests on the TX1, using the gst-launch-1.0 utility:
gst-launch-1.0 nvcamerasrc fpsRange="120.0 120.0" ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)120/1' ! nvtee ! nvvidconv flip-method=2 ! 'video/x-raw(memory:NVMM, format=(string)I420' ! nvoverlaysink -e
with the camera pointed at a stopwatch…
What I see is a latency of about 200ms. Is this normal, or is there a way to reduce the latency?
Also, how do I know whether the target resolution and frame rate are being used? The textual output reads: NvCameraSrc: Trying To Set Default Camera Resolution. Selected 1280x720 FrameRate = 120.000000 …
Thanks in advance!
kayccc
April 29, 2016, 2:59am
#2
Hi Stupig,
Please try running the ‘max perf script’ listed below on TX1 to see if any help to reduce the latency:
#!/bin/sh
# turn on fan for safety
echo "Enabling fan for safety..."
if [ ! -w /sys/kernel/debug/tegra_fan/target_pwm ] ; then
echo "Cannot set fan -- exiting..."
fi
echo 255 > /sys/kernel/debug/tegra_fan/target_pwm
echo 0 > /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable
echo 1 > /sys/kernel/cluster/immediate
echo 1 > /sys/kernel/cluster/force
echo G > /sys/kernel/cluster/active
echo "Cluster: `cat /sys/kernel/cluster/active`"
# online all CPUs - ignore errors for already-online units
echo "onlining CPUs: ignore errors..."
for i in 0 1 2 3 ; do
echo 1 > /sys/devices/system/cpu/cpu${i}/online
done
echo "Online CPUs: `cat /sys/devices/system/cpu/online`"
# set CPUs to max freq (perf governor not enabled on L4T yet)
echo userspace > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
cpumax=`cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies | awk '{print $NF}'`
echo "${cpumax}" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
echo "CPU${i}: `cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq`"
done
# max GPU clock (should read from debugfs)
cat /sys/kernel/debug/clock/gbus/max > /sys/kernel/debug/clock/override.gbus/rate
echo 1 > /sys/kernel/debug/clock/override.gbus/state
echo "GPU: `cat /sys/kernel/debug/clock/gbus/rate`"
# max EMC clock (should read from debugfs)
cat /sys/kernel/debug/clock/emc/max > /sys/kernel/debug/clock/override.emc/rate
echo 1 > /sys/kernel/debug/clock/override.emc/state
echo "EMC: `cat /sys/kernel/debug/clock/emc/rate`"
njal
November 17, 2017, 2:42pm
#3
Did it help to run this script Stupig?
