Jetson TX1 OV5693 high frame rate not working?
I am unable to get the nvcamerasrc element to supply 120FPS video from the OV5693 camera. I have compiled a more recent version of gstreamer (1.6.2) and tested using the fpsdisplaysink (though checking timing with nvcamerasrc debug messages turned way up works too):
ubuntu@tegra-ubuntu:~/$ GST_DEBUG=fpsdisplaysink:5 ~/gst-1.6.2/bin/gst-launch-1.0 nvcamerasrc fpsRange="120 120" intent=3 ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)I420, framerate=(fraction)120/1' ! queue ! fpsdisplaysink video-sink=fakesink sync=false async=true
Invalid FPSRange Input
Setting pipeline to PAUSED ...
0:00:00.036251139 20420    0xf95a0 DEBUG         fpsdisplaysink fpsdisplaysink.c:444:fps_display_sink_start:<fpsdisplaysink0> Use text-overlay? 1
Available Sensor modes :
2592 x 1944 FR=30.000000 CF=0x10d9208a isAohdr=0
2592 x 1458 FR=30.000000 CF=0x10d9208a isAohdr=0
1280 x 720 FR=120.000000 CF=0x10d9208a isAohdr=0
2592 x 1944 FR=24.000000 CF=0x10d9208a isAohdr=1
Pipeline is live and does not need PREROLL ...
NvCameraSrc: Trying To Set Default Camera Resolution. Selected 1280x720 FrameRate = 120.000000 ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:01.126878158 20420    0xe4c60 DEBUG         fpsdisplaysink fpsdisplaysink.c:376:display_current_fps:<fpsdisplaysink0> <b>Updated max-fps to 31.716115</b>
0:00:01.127055813 20420    0xe4c60 DEBUG         fpsdisplaysink fpsdisplaysink.c:380:display_current_fps:<fpsdisplaysink0> Updated min-fps to 31.716115
0:00:01.629408789 20420    0xe4c60 DEBUG         fpsdisplaysink fpsdisplaysink.c:380:display_current_fps:<fpsdisplaysink0> Updated min-fps to 29.848076
0:00:02.694688479 20420    0xe4c60 DEBUG         fpsdisplaysink fpsdisplaysink.c:380:display_current_fps:<fpsdisplaysink0> Updated min-fps to 29.779070
0:00:05.295328151 20420    0xe4c60 DEBUG         fpsdisplaysink fpsdisplaysink.c:380:display_current_fps:<fpsdisplaysink0> Updated min-fps to 29.701780
I see the mode is implemented in the nvidia OV5693 driver and it looks like it is trying to configure 120fps output, but it isn’t happening.
Any clarification regarding the supported modes of the ov5693 and if 1280x720@120fps is attainable?
Hi, NaterGator.
Thank you for reporting this issue, we’re fixing the error you mentioned above, and will include that change in coming release.
you can look up the pdf about the ov5693, that could reach the speed at 30 fps
speed table of ov5693
25921944 30fps croping + scaling
2112
1188 30fps croping + scaling
19201080 30fps croping + scaling
1536
864 30fps croping + binning
1280720 60fps/120fps croping + binning + scaling
640
480 90fps/120fps croping + binning + scaling
320*240 200fps croping + binning + scaling
4:3 full resolution 5MP 30fps full frame
16:9 cropped 30fps crop + scale 1.23 25921458
16:9 1080p using scalar 30fps crop + scale 1.23 2592
1458
16:9 720p using scalar 60fps crop + scale 2592*1458
