When I run Jetpack 2.3 from a VM (virtual box), everything installs okay. The post installation is where it fails, it fails to install Vision works. I install it on the TX1 like it tells me to (via sudo apt-get install), and it tells me to press enter when finished on the host to continue, and I do, and nothing happens, it just hangs up in the post installation step. Is this because I am doing this over Wifi, using a Virtual Machine, or maybe both? Thanks!
I had the same issue when installing over WiFi. Installing over a wired connection resolved the problem so I did not look into the reason. The install docs actually do specify using a wired network.
Thanks! I installed over Ethernet, and all seems to be going well.
