Jetson TX1 replacing Processor SoM
I am planning to replace the Tegra X1 processor SoM on the jetson Tx1 with another Tegra X1 SoM. This new SoM does not have any L4T preloaded. Will I be able to flash this with the same steps I follow for flashing new version of L4T?
Yes, you should have no problem using Jetpack to flash a blank module. Even if L4T is not installed, the USB bootloader will still be present.
