JETSON TX1 - TEGRA LINUX DRIVER PACKAGE PROBLEM
I did a few steps:
  • Downloaded from https://developer.nvidia.com/linux-tegra
    Tegra210_Linux_R28.2.0_aarch64.tbz2
    Tegra_Linux_Sample-Root-Filesystem_R28.2.0_aarch64.tbz2
  • sudo tar xpf …/Downloads/Tegra210_Linux_R28.2.0_aarch64.tbz2
    cd Linux_for_Tegra/rootfs/
    sudo tar xpf …/Downloads/Tegra_Linux_Sample-Root-Filesystem_R28.2.0_aarch64.tbz2
    cd Linux_for_Tegra
    sudo ./apply_binaries.sh
    –> /usr/src/linux-headers-4.4.38-tegra
    Installing Image into /boot in target rootfs
    Installing the board *.dtb files into /boot in target rootfs
    Success!
  • sudo ./flash.sh jetson-tx1 mmcblk0p1
    L4T BSP Information:
    R28 (release), REVISION: 2.0, GCID: 10567845, BOARD: t210ref, EABI: aarch64,
    DATE: Fri Mar 2 04:58:16 UTC 2018
    ./flash.sh: line 591: ./tegrarcm: cannot execute binary file: Exec format error
    Error: probing the target board failed.
    Make sure the target board is connected through
    micro-B USB port and is in recovery mode.
  • also, with Jetson TX1
    sudo reboot --force forced-recovery
    same result
  • lsusb -d 0955:7721
    Bus 001 Device 005: ID 0955:7721 NVidia Corp.
    looks likes Jetson TX1 in recovery mode
how to fix ?
