Jetson TX1 u-boot network problem--EHCI timed out on TD - token=0x88008d80
Thanks for the replay.
I tried your method,sorry the probelm still exists.I don’t have the AX8872B’s datasheet.I can’t figure it out.
I found the code for your particular device fairly easily, but it appears the U-Boot config for enabling that device is not clear. I had hoped CONFIG_USB_ETHER_ASIX would have done the job. I am unsure, but it does appear that around the time of that particular U-Boot release there was an effort to move some USB ethernet drivers out of USB and configure within ethernet, but I don’t know enough about it to be of much use. I suspect the missing config is related to the desire to move some devices out of USB and into ethernet. The code for that device is there, the trick is to figure out how to enable it.
Thanks for the reply.
I understand.I will give it a try.
Hi wjljy1,
Have this issue been clarified and fixed?
Any result can be shared?
