Jetson TX1 WiFi issues
I’ve been having issues connecting to the WiFi using two of my Jetson TX1 boards that I recently upgraded to Jetpack 3.1
When I try to connect to WiFi using
sudo nmcli dev wifi con "WIFI_SSID" password "WIFI_PASSWORD"
On two different WiFi-APs (both from TP-Link) I am getting two different behaviours.
On AP #1, I get
Error: No network with SSID 'WIFI_SSID' found.
This is strange as all the other computers and phones, including some other Jetson boards which are also on my desk are happily connected to that same SSID. I tried
sudo nmcli dev wifi list
and I see ALL other SSIDs in the area except this specific AP.
On AP #2, I get
Error: Connection activation failed: (7) Secrets were required, but not provided.
I looked at dmesg output and it shows…
[ 2409.435899] CFG80211-ERROR) wl_cfg80211_connect : Connectting with10:7b:44:57:ce:e0 channel (6) ssid "WIFI_SSID2", len (5)
[ 2409.480106] wl_bss_connect_done succeeded with 10:7b:44:57:ce:e0
[ 2409.585712] wl_bss_connect_done succeeded with 10:7b:44:57:ce:e0
[ 2409.623783] cfg80211: Regulatory domain changed to country: US
[ 2409.632428] cfg80211:  DFS Master region: FCC
[ 2409.637204] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2409.653421] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 2409.664744] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 2409.677686] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 2409.689490] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm), (0 s)
[ 2409.699987] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 2409.710416] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 2413.533541] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_DISASSOC_IND
[ 2413.582472] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 12, reason=2 from 10:7b:44:57:ce:e0
[ 2413.609244] cfg80211: World regulatory domain updated:
[ 2413.616761] cfg80211:  DFS Master region: unset
[ 2413.622436] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2413.637229] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2413.650230] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2413.660680] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 2413.671192] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 2413.683235] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 2413.695307] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 2413.705965] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 2413.716530] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 2413.734690] cfg80211: Regulatory domain changed to country: SG
[ 2413.743012] cfg80211:  DFS Master region: FCC
[ 2413.747240] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 2413.764650] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 2413.775152] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 2413.787138] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2400 mBm), (0 s)
[ 2413.799106] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2400 mBm), (0 s)
[ 2413.809730] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
Does anyone know what this error means?
I’ve already tried using wifi-config-check.sh and it showed no error.
HI notthetup,
Are both devices tegra devkit?
I will try nm on my devkit today as well. Please wait for my result.
Thanks for patience.
Thanks Wayne.
Not sure what you mean by tegra devkit. They’re both Jetson TX1 boards. How can I check this?
-Chinmay
Never mind, just wanted to make sure you are using a tegra devkit instead of a custom carrier board.
-Wayne
Yes. I’m not using custom carrier boards. They’re both NVIDIA Jetson TX1 Development Kits.
Hi notthetup,
We try to connect six different Wi-Fi ap are no issue.
Please check your wifi router (your settings or restart it).
Do you know what channel the missing SSID is broadcasting on? The TX-1 and your router may not support the same 5Ghz bands.
Thanks @carolyuu.
Good point @sperok. I’ll check the channels of my router later today.
Hi notthetup,
Have you resolved this problem?
Any good result?
Thanks for reminding me about this @kayccc.
I restarted my router a couple of times and the issues went away. Strangely enough.
