H
I don’t believe the actual TX2 4GB module is officially available yet (ETA at distributors is end of June), and it will be supported in the next JetPack release. If you have a pre-release version of TX2 4GB, then contact your NVIDIA representative for the EA software for it.
I see now that Arrow has the 4GB module listed, but not in stock. I inquired about lead times are they are quoting 16 weeks. Can NVIDIA confirm this delayed availability?
Thank you
Hi Ahuska, there is a shipment of TX2 4GB modules currently enroute to Arrow, so the lead time shouldn’t be 16 weeks. That’s their standard lead time if they don’t have it currently in stock. They should be able to update that shortly after they receive this shipment.
It’s been almost 2 weeks and Arrow does not show these in stock yet. Is there an ETA on when these will be available? Also, do we know what quantity is in the shipment?
Hi Undertow10,
The first shipment sold out immediately upon receipt. Another order has been placed. There are a couple of ways to ensure you are included in the next order that we receive depending upon your quantity needs.
PM me to discuss
Hi!
I have a “regular” TX2, if I use the “Jetson TX2 as Jetson TX2 4GB Configuration Package”, can I go back to original “8GB configuration” latter?
Hi alfredosalvarani, the change isn’t permanent - you can reset it by reflashing your TX2 with the standard JetPack or SDK Manager tool.
Is there any way to get TX2/4GB to work with Jetpack 3.3 or must we upgrade to 4.2.1?
Hi stmpixels, JetPack 4.2.1 is the first version that supports the actual Jetson TX2 4GB hardware, so please use JetPack 4.2.1.
When i flash TX2 of 4GB sdk.Occur error as follows:
[ 4.9027 ] […] 100%
[ 4.9416 ] Sending bct_mb1
[ 4.9717 ] […] 100%
[ 5.3993 ]
[ 5.3995 ] Generating blob
[ 5.4022 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 5.4043 ]
[ 5.4064 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 5.4098 ]
[ 5.4132 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 5.4152 ] Assuming zero filled SBK key
[ 5.4285 ]
[ 5.4309 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 5.4329 ]
[ 5.4345 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 5.4359 ]
[ 5.4382 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 5.4647 ]
[ 5.4665 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 5.4677 ] Assuming zero filled SBK key
[ 5.4706 ]
[ 5.4724 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 5.4741 ]
[ 5.4756 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 5.4769 ]
[ 5.4781 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 5.4795 ]
[ 5.4811 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 5.4822 ] Assuming zero filled SBK key
[ 5.4851 ]
[ 5.4867 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 5.4894 ]
[ 5.4907 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 5.4919 ]
[ 5.4933 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 5.4989 ]
[ 5.5008 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 5.5020 ] Assuming zero filled SBK key
[ 5.5700 ]
[ 5.5717 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 5.5765 ]
[ 5.5783 ] tegrahost_v2 --align blob_bpmp.bin
[ 5.5794 ]
[ 5.5804 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 5.5828 ]
[ 5.5843 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 5.5854 ] Assuming zero filled SBK key
[ 5.6027 ]
[ 5.6043 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 5.6063 ]
[ 5.6075 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2.dtb
[ 5.6085 ]
[ 5.6094 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2.dtb zerosbk
[ 5.6118 ]
[ 5.6131 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2_sigheader.dtb_list.xml
[ 5.6141 ] Assuming zero filled SBK key
[ 5.6245 ]
[ 5.6260 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2_sigheader.dtb.hash zerosbk
[ 5.6277 ]
[ 5.6290 ] tegrahost_v2 --align blob_tos.img
[ 5.6301 ]
[ 5.6318 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 5.6332 ]
[ 5.6346 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 5.6355 ] Assuming zero filled SBK key
[ 5.6379 ]
[ 5.6391 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 5.6406 ]
[ 5.6422 ] tegrahost_v2 --align blob_eks.img
[ 5.6432 ]
[ 5.6441 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 5.6451 ]
[ 5.6462 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 5.6472 ] Assuming zero filled SBK key
[ 5.6478 ]
[ 5.6492 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 5.6504 ]
[ 5.6515 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-as-0888.dtb
[ 5.6526 ]
[ 5.6535 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-as-0888.dtb zerosbk
[ 5.6558 ]
[ 5.6571 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-as-0888_sigheader.dtb_list.xml
[ 5.6580 ] Assuming zero filled SBK key
[ 5.6785 ]
[ 5.6801 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-as-0888_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-as-0888_sigheader.dtb.hash zerosbk
[ 5.6816 ]
[ 5.6829 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 5.6837 ] number of images in blob are 9
[ 5.6844 ] blobsize is 3610200
[ 5.6847 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 190048
[ 5.6868 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79600
[ 5.6882 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 5.6893 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 5.6915 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 5.6930 ] Added binary blob_tegra186-a02-bpmp-p3310-1000-c04-as-0888-ucm2_sigheader.dtb.encrypt of size 327584
[ 5.6951 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 5.6960 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 5.6968 ] Added binary blob_tegra186-quill-p3310-1000-as-0888_sigheader.dtb.encrypt of size 279056
[ 5.7003 ]
[ 5.7004 ] Sending bootloader and pre-requisite binaries
[ 5.7017 ] tegrarcm_v2 --download blob blob.bin
[ 5.7026 ] Applet version 01.00.0000
[ 5.9471 ] Sending blob
[ 6.2059 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
Hi 504566020, are you flashing with JetPack 4.2.1 from a PC that has Ubuntu 16.04 or 18.04 natively installed (not VM)? Can you try changing to a different USB port on the PC, for example a USB2 port?
If you continue experiencing the behavior, please follow up with this topic about the issue:
