Jetson TX2 8 camera using but error is occur
I made a custom MIPI camera driver for Jetson TX2, the driver was loading and I used to get the following output in dmesg
[ 6.328502] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–7 bound
[ 6.336044] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–6 bound
[ 6.343522] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–5 bound
[ 6.351066] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–4 bound
[ 6.358559] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–3 bound
[ 6.366015] tegra-vi4 15700000.vi: cannot find remote port parent
[ 6.373215] tegra-vi4 15700000.vi: cannot find remote port parent
How can i fix this probrem
hello k.sakai,
may I double confirm the L4T release version you’re working with?
you must enable virtual channel support for 8-cam use-case.
please refer to developer guide, Jetson Virtual Channel with GMSL Camera Framework.
besides, you may see-also Debugging Tips section for troubleshooting.
Thank you for the feedback L4T version is Jetson Linux R32.7.4.
After reading the developer guide, I noticed that the following content was missing.
remote-endpoint = sensor
After modification, the following was recognized
However, a kernel panic now occurs during startup.
I will ask about this again in a separate thread.
hello k.sakai,
please double check your sensor port bindings,
you may see-also reference driver for using VC supports.
for instance,
$public_sources/kernel_src/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-modules/tegra186-camera-imx390-a00.dtsi
