Hello @DaneLLL, I tried it and it failed with other error in my previous post. My setup is now pure L4T 32.4.3 with all additional packages installed trough sdkmanager.
We would suggest build the package from source in local folder and check if you can build/run your application in the folder. Please do the steps:
Get source code
$ echo "deb https://repo.download.nvidia.com/jetson/ffmpeg main main" | sudo tee -a /etc/apt/sources.list
$ echo "deb-src https://repo.download.nvidia.com/jetson/ffmpeg main main" | sudo tee -a /etc/apt/sources.list
$ sudo apt update
$ apt source ffmpeg
Configure and build:
ffmpeg-4.2.2$ ./configure --enable-nvv4l2dec --enable-libv4l2 --extra-libs="-L/usr/lib/aarch64-linux-gnu/tegra -lnvbuf_utils" --extra-cflags="-I /usr/src/jetson_multimedia_api/include/"
ffmpeg-4.2.2$ make
Verify hardware decoding by setting LD_LIBRARY_PATH and running the command:
