I used rt5651 to output audio.
However, the audio gain is low, so it is hard to hear.
I tried the following as a way to increase the gain.
- rt5651 gain adjustment → max gain setting
amixer cset -c tegrasndt186ref name=“x DAC1 Playback Volume” 175
amixer cset -c tegrasndt186ref name=“x HP Playback Volume” 39
amixer cset -c tegrasndt186ref name=“x OUT Playback Volume” 39
- Set master volume control
amixer -c tegrasndt186ref cset name=“MVC1 Vol” 16000
I tried the above method, but the audio gain is not significantly improved.
Please review how we can improve.
Hi there,
I am afraid I am unable to help with this specific question, but if you don’t mind I will move your topic to the Jetson TX2 experts and I am sure you will receive great support.
Hi Sangjina,
I see that you have set peak gain on codec and MVC side. But confirm if MVC is included in the playback path through below settings
amixer -c tegrasndt186ref cset name="MVC1 Mux" ADMAIF1
amixer -c tegrasndt186ref cset name="I2S1 Mux" MVC1
If you have included MVC in the path, you could do I2S loopback once and check if data signal levels are fine uptil Jetson. Below additional controls/commands will be needed for loopback
amixer -c tegrasndt186ref cset name="ADMAIF1 Mux" "I2S1"
amixer -c tegrasndt186ref cset name="I2S1 Loopback" "on"
arecord -D hw:tegrasndt186ref,0 -r <rate> -c <channels> -f <sample_format> <out.wav>
If the data is getting de-amplified inside codec (i.e after getting transmitted from Jetson I2S to codec), you might need to check once with codec vendor as I see that you have set all possible volume related settings on codec side
