Hi all
I found this topic (https://devtalk.nvidia.com/default/topic/1047809/jetson-tx2/auto-power-on-with-c02-carrier-board/) written by Trumany (Moderator) which says exactly what I need about auto-power-on on Jetson TX2 with the C02 board, however I really need help with some pictures about this procedure because I could not identify every step by reading it.
Have anyone done this procedure once before?
C02 board does not support Auto-Power-On function directly, it requires a few more changes to enable that:
- Install 0 Ohm, 0402 resistor at R313
Asserts ACOK to allow Jetson TX2 or Jetson TX2 4GB to Auto-Power-On. - Move R501, 10k, 0402, resistor to R287
Enables the VDD_IN supply to the module connector as soon as the power is applied (disables hot-plug protection) - Remove R383
Disables the ON control from the pushbutton Micro-Controller - Remove R384
Removes the VDD_IN Bleeder resistor to keep this from consuming power during normal operation. - Add wire across Q47 pin 2 and 3.
Force Button Micro-Controller in Mobile PMIC Mode (allows Jetson TX2i to function as if it were in a P2597_B04 carrier
board – will boot when power is attached without button press)
Regards
