I have a TX2 Developer Kit and I follow the instruction to flash it with JetPack-L4T-3.2.1-linux-x64_b23. Everything is good and I can build the sample under vision works. I run the visonwroks sample program “nvx_sample_nvgstcamera_capture” with the onboard camera. It is come up and running good, but it will crash after about 1 or 2 hours. The window changes from color to white and black. From the terminal window, there is no error message. can anyone repeat it? I am not sure that I get defect hardware issue or I did something wrong.
The root cause is the consumer can’t deal with the high frame rate producer.
We suggest to set the fpsRange to 30 if the sensor has higher frame mode to avoid this issue.
