Jetson TX2 can not communicate with Android clients using WiFi Direct
Jetson TX2 installed system is Ubuntu 16, communication is to use wpa_supplicant.
The implementation is described in the section “Steps prior to R8.2 release” in http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_NLCP_WiFi_Direct_Configuration_Scripts
But when I p2p_connect, the link will be broken within 10 seconds of success
wpa_cli log as follows:
> p2p_connect c2:ee:fb:f7:1e:18 pbc
OK
<3>P2P-FIND-STOPPED
<3>P2P-GO-NEG-SUCCESS role=GO freq=5220 ht40=1 peer_dev=c2:ee:fb:f7:1e:18 peer_iface=c2:ee:fb:f7:1e:18 wps_method=PBC
<3>P2P-GROUP-FORMATION-SUCCESS
<3>P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-MS" freq=5220 passphrase="pbiRQiEs" go_dev_addr=02:04:4b:8c:a5:05
<3>AP-STA-CONNECTED c2:ee:fb:f7:1e:18 p2p_dev_addr=c2:ee:fb:f7:1e:18
<3>AP-STA-DISCONNECTED c2:ee:fb:f7:1e:18 p2p_dev_addr=c2:ee:fb:f7:1e:18
<3>P2P-DEVICE-LOST p2p_dev_addr=fe:3f:db:2f:c7:15
<3>P2P-DEVICE-LOST p2p_dev_addr=c2:ee:fb:f7:1e:18
<3>P2P-DEVICE-LOST p2p_dev_addr=12:2a:b3:dc:88:ec
Android log as follows:
07-11 20:50:08.589 6784-6784/? I/wpa_supplicant: p2p0: WPA: Key negotiation completed with 02:04:4b:8c:25:05 [PTK=CCMP GTK=CCMP]
07-11 20:50:08.591 6784-6784/? I/wpa_supplicant: p2p0: CTRL-EVENT-CONNECTED - Connection to 02:04:4b:8c:25:05 completed [id=1 id_str=]
07-11 20:50:08.595 6784-6784/? I/wpa_supplicant: P2P-GROUP-STARTED p2p0 client ssid="DIRECT-t4" freq=5240 go_dev_addr=02:04:4b:8c:a5:05
07-11 20:50:08.612 1390-1626/? D/WifiP2pService: GroupCreatedStatemPendingReformGroupIndication=false
07-11 20:50:08.613 7756-7756/com.amap.ai.wifidirectdemo D/wifidirectdemo: P2P peers changed
07-11 20:50:08.618 7756-7756/com.amap.ai.wifidirectdemo D/wifidirectdemo: Peer status :0
07-11 20:50:08.622 7756-7756/com.amap.ai.wifidirectdemo D/wifidirectdemo: Peer status :0
07-11 20:50:08.721 22926-22926/? E/dhcpcd: fopen `/system/etc/dhcpcd/dhcpcd.conf': No such file or directory
07-11 20:50:08.722 22926-22926/? I/dhcpcd: version 5.5.6 starting
07-11 20:50:08.723 22926-22926/? E/dhcpcd: fopen `/system/etc/dhcpcd/dhcpcd.conf': No such file or directory
07-11 20:50:08.762 22926-22926/? I/dhcpcd: p2p0: rebinding lease of 192.168.49.144
07-11 20:50:09.498 1390-2404/? D/GpsLocationProvider: reportNmea $GPGSA,A,1,,,,,,,,,,,,,,,*1E  timestamp = 1499777409497
07-11 20:50:10.241 1390-1432/? I/ActivityManager: [BgDetect]chkExcessCpu level: 1 doKills: true auto_mode: false uptime: 300085
07-11 20:50:10.258 1390-1432/? I/ActivityManager: [BgDetect]checkExcessiveCpuUsageLocked level 1 in 64ms
07-11 20:50:10.354 723-1788/? D/audio_hw_primary: out_standby: enter: stream (0xf4c03380) usecase(1: low-latency-playback)
07-11 20:50:10.391 723-1788/? D/audio_hw_primary: disable_audio_route: reset and update mixer path: low-latency-playback quat_i2s
07-11 20:50:10.393 723-1788/? D/soundtrigger: audio_extn_sound_trigger_update_stream_status: uc_id 1 of type 0 for Event 2, with Raise=0
07-11 20:50:10.394 723-1788/? D/hardware_info: hw_info_append_hw_type : device_name = speaker
07-11 20:50:10.394 723-1788/? D/audio_hw_primary: disable_snd_device: snd_device(2: speaker)
07-11 20:50:10.407 723-1788/? D/aud_dev_arbi: releaseOneDevice: not sending command, device argument (2) does not match any registered device
07-11 20:50:10.407 723-1788/? D/aud_dev_arbi: releaseOneDevice: device 2 owner is 0
07-11 20:50:10.407 723-1788/? I/soundtrigger: audio_extn_sound_trigger_update_device_status: device 0x2 of type 0 for Event 0, with Raise=0
07-11 20:50:12.019 1390-1430/? D/DeviceIdleController: handleMessage(5)
07-11 20:50:12.020 1390-1430/? D/DeviceIdleController: Removing UID 10004 from temp whitelist
07-11 20:50:12.020 1390-1430/? D/DeviceIdleController: Setting wakelock temp whitelist to []
07-11 20:50:12.497 1390-2404/? D/GpsLocationProvider: reportNmea $GPGSA,A,1,,,,,,,,,,,,,,,*1E  timestamp = 1499777412497
07-11 20:50:12.628 1390-1390/? I/DeviceIdleController: updateChargingLocked: charging=true
07-11 20:50:12.628 1390-1390/? I/DeviceIdleController: becomeActiveLocked, reason = charging
07-11 20:50:12.630 3094-3094/? D/AbstractProcessor: onBatteryChange Percent:94 State:2
07-11 20:50:13.765 22926-22926/? I/dhcpcd: p2p0: broadcasting for a lease
07-11 20:50:18.640 1390-1390/? I/DeviceIdleController: updateChargingLocked: charging=true
07-11 20:50:18.640 1390-1390/? I/DeviceIdleController: becomeActiveLocked, reason = charging
07-11 20:50:18.643 3094-3094/? D/AbstractProcessor: onBatteryChange Percent:94 State:2
07-11 20:50:22.013 1390-1612/? V/AlarmManager: Triggering alarm #0: Alarm{d0ab6a3 type 3 when 21992479 com.amap.android.ams}operation =Intent { act=com.amap.android.ams.nlp.ALARM_WAKEUP_LOCATOR }
07-11 20:50:22.015 1390-1432/? D/DeviceIdleController: Adding AppId 10004 to temp whitelist
07-11 20:50:22.015 1390-1432/? D/DeviceIdleController: Setting wakelock temp whitelist to [10004]
07-11 20:50:22.016 2392-2746/? I/amsnl: ar
07-11 20:50:22.017 2392-2746/? I/amsnl: t:false, fl: false, p: 20000, ce: true, we: true
07-11 20:50:22.018 1390-2482/? D/ConnectivityService: returning Blocked NetworkInfo for ifname=wlan0, uid=10004
07-11 20:50:22.019 2392-2746/? I/amsnl: c: false, w: true, t: true, l: false
07-11 20:50:22.020 2392-2746/? I/amsnl: crs
07-11 20:50:22.020 2392-2746/? I/amsnl: qg
07-11 20:50:22.028 2392-2746/? I/amsnlp: isConnected, isIdle: false isIgnoreBatOpt: false
07-11 20:50:22.030 1390-1416/? D/ConnectivityService: returning Blocked NetworkInfo for ifname=wlan0, uid=10004
07-11 20:50:22.032 2392-2746/? I/e: hot: htMem:{wx4gd2={"x":"{\"key\":\"RVBMVVNGN0E5MzE2N1NURUw=#network#wifi\",\"lat\":39.99216,\"lon\":116.466551}","time":1499424655974,"num":3}}
07-11 20:50:22.032 2392-2746/? I/e: hot: lst:[wx4gd2]
07-11 20:50:22.033 2392-2746/? E/amsnlp: error -3
07-11 20:50:22.055 2392-2746/? I/amsnl: csr
07-11 20:50:22.056 2392-2746/? I/amsnl: t:false, fl: false, p: 20000, ce: true, we: true
07-11 20:50:22.058 2392-2746/? I/amsnl: rl
07-11 20:50:22.059 2392-2746/? I/amsnl: c: false, w: true, t: false, l: false
07-11 20:50:22.497 1390-2404/? D/GpsLocationProvider: reportNmea $GPGSA,A,1,,,,,,,,,,,,,,,*1E  timestamp = 1499777422497
07-11 20:50:24.642 1390-1390/? I/DeviceIdleController: updateChargingLocked: charging=true
07-11 20:50:24.642 1390-1390/? I/DeviceIdleController: becomeActiveLocked, reason = charging
07-11 20:50:24.649 3094-3094/? D/AbstractProcessor: onBatteryChange Percent:94 State:2
07-11 20:50:32.066 1390-1430/? D/DeviceIdleController: handleMessage(5)
07-11 20:50:32.067 1390-1430/? D/DeviceIdleController: Removing UID 10004 from temp whitelist
07-11 20:50:32.067 1390-1430/? D/DeviceIdleController: Setting wakelock temp whitelist to []
07-11 20:50:32.498 1390-2404/? D/GpsLocationProvider: reportNmea $GPGSA,A,1,,,,,,,,,,,,,,,*1E  timestamp = 1499777432498
07-11 20:50:36.642 1390-1390/? I/DeviceIdleController: updateChargingLocked: charging=true
07-11 20:50:36.643 1390-1390/? I/DeviceIdleController: becomeActiveLocked, reason = charging
07-11 20:50:36.649 3094-3094/? D/AbstractProcessor: onBatteryChange Percent:94 State:2
07-11 20:50:39.061 1390-22925/? D/NetUtils: dhcp_start failed : p2p0
07-11 20:50:39.062 1390-22925/? E/DhcpStateMachine: DHCP request failed on p2p0: Timed out waiting for DHCP to finish
07-11 20:50:39.064 1390-1626/? E/WifiP2pService: DHCP failed
07-11 20:50:39.103 6784-6784/? I/wpa_supplicant: p2p0: CTRL-EVENT-DISCONNECTED bssid=02:04:4b:8c:25:05 reason=3 locally_generated=1
07-11 20:50:39.104 6784-6784/? E/wpa_supplicant: eap_proxy: eap_proxy_notify_config
07-11 20:50:39.104 6784-6784/? I/wpa_supplicant: P2P-GROUP-REMOVED p2p0 client reason=REQUESTED
Hi ddlx,
Please try with following steps.
1.Wpa_cli -I wlan0 p2p_add_group
2.Wpa_cli //you will enter in wpa_cli shell
3.P2p_find
4.P2p_peers
5.Wps_pin any //note the pin prompted on shell
6.On android device, in wifidirect scan page, click on mac of DUT and enter pin from step #5
Connected //Attaching logs, look for AP-STA-CONNECTED
Hi, WayneWWW,
Thanks for your reply.
I tried to follow the method you said, the result is the same, within 10 seconds to disconnect the link.
Are there any other ideas?
The log is as follows:
> wps_pin any
79027175
// ... Android devices use pin code to link, Jetson TX2 shows Log as follows
<3>CTRL-EVENT-EAP-STARTED c2:ee:fb:f7:1e:18
<3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
<3>CTRL-EVENT-EAP-PROPOSED-METHOD vendor=14122 method=254
<3>WPS-REG-SUCCESS c2:ee:fb:f7:1e:18 dc4d065f-6148-5388-a0d4-9187e0ea0a78
<3>WPS-SUCCESS
<3>CTRL-EVENT-EAP-FAILURE c2:ee:fb:f7:1e:18
// ... The link was successful and broke in 10 seconds
Hi ddlx,
This is sometimes related to both peers. Could you try other android phone and see if this is issue from tegra?
Hi, WayneWWW,
I tried two Android phones, there are the same problem.
However, the use of WiFi Direct links between two Android phones is good.
Is it a problem with Jetson TX2?
I am checking this internally. Thanks.
Hi ddlx,
Could you try to run the test again with dhcp server setup?
Please try following steps:
Steps:
1) Install isc-dhcp-server Install isc-dhcp-server (sudo apt install isc-dhcp-server)
2) Edit the file /etc/default/isc-dhcp-server and set INTERFACES like this:
   INTERFACES="p2p-wlan0-0"
3) In /etc/dhcp/dhcpd.conf Find below lines and put # before it. It should look like after editing
   # option definitions common to all supported networks…
   #option domain-name “example.org”;
   #option domain-name-servers ns1.example.org, ns2.example.org;
4) Again comment out following lines too
   #default-lease-time 600;
   #max-lease-time 7200;
5) Add following lines at end
   subnet 10.10.0.0 netmask 255.255.255.0 {
           range 10.10.0.2 10.10.0.16;
           option domain-name-servers 8.8.4.4, 208.67.222.222;
           option routers 10.10.0.1;
7)In /etc/network/interfaces, Add below
   auto p2p-wlan0-0
   iface p2p-wlan0-0 inet static
   address 10.10.0.1
8).wpa_cli -i wlan0 p2p_group_add
9) wpa_cli //you will enter in wpa_cli shell
10)p2p_find
10)p2p_peers
11) p2p_stop
12)wps_pin any //note the pin prompted on shell
13)On android device, in wifidirect scan page, click on mac of DUT and enter pin from step #5
14) If you see ubuntu p2p interface as GO role, you need to start dhcp server(follow next 2 steps)
15) ifconfig p2p-wlan0-0 10.10.0.1
16)  sudo service isc-dhcp-server start
Hey WayneWWW,
I recently ran into the same problem like ddlx. I have a NVIDIA Jetson TX2 development kit and installed Ubuntu 16.04. My Android device is a LG VK810 Tablet running Android 5.0.1.
I followed your instructions in the approved answer above. I should mention that I was not able to set up WifiDirect as mentioned on this page: http://processors.wiki.ti.com/index.php/OMAP_Wireless_Connectivity_NLCP_WiFi_Direct_Configuration_Scripts. Maybe that’s the issue. I couldn’t figure out if your answer is a complete one.
Anyway after generating a random pin with wps_pin any, I can see my Jetson TX2 in the Android’s WiFi Direct Menu but when I try to connect by clicking it, I send out an invitation to the Jetson TX2 with a random generated pin again. There is no option to type in a pin.
When sending out that Android based invitation to the Jetson, I also cannot connect to it with p2p_connect . The output only shows FAILED.
Do you have an idea? Is there maybe a newer way to approach this issue?
Did someone manage to establish a stable connection between the jetson and an android phone by now?
