Hi guys,
i know this is not the first time someone have this kind of error, but as far as i am trying the solution from similar problem in this forum, i haven’t got my jetson TX2 working properly.
let me tell you how i flash my jetson tx2.
- just following the instruction. On page menu that show how jetson and host and internet are connected, i chose the second choice, where my jetson and host are connected through usb-micro usb, also cross type ethernet cable.
- go to force recovery, and everything seems normal at this point, process took a while, until they want me to put ip address manually or automatically. But i cannot choose either of those.
- also i canntot install some library because “other apt-command running on device while installing” and there is several connection reset.
after i close the installation terminal, and reboot jetson, the display stuck with this line that appear repeatedly
[ 2199.143304] PD DISP2 index4 DOWN
[ 2199.143421] PD DISP1 index3 DOWN
[ 2199.143424] PD DISP0 index2 DOWN
[ 3062.697182] tegradc 15210000.nvdisplay: unblank
[ 3062.697194] PD DISP0 index2 UP
[ 3062.697269] PD DISP1 index3 UP
[ 3062.697270] PD DISP2 index4 UP
if anything is not clear enough please tell me about it.
thanks guys
