Jetson TX2 cannot be opened and when I press ctrl + alt + F1 ~F6 nothing happened
[0.516934] pca953x 0-0077: failed reading register
[1.257067] ina3221x 0-0042: ina3221 reset failure status: Oxffffff87
[1.257401] ina3221x 0-0043: ina3221 reset failure status: Oxffffff87
cp: not writing through dangling symlink ‘etc/resolu.conf’
[1.804263] cgroup: cgroup2: unknown option “nsdelegate”
[2.533766] usb 1-3-port1: Cannot enable. Maybe the USB cable is bad?
[3.125264] using random self ethernet address
[3.159921] using random host ethernet address
[3.417483] usb 1-3-port1: Cannot enable. Maybe the USB cable is bad?
[3.751161] using random self ethernet address
[3.792768] using random host ethernet address
[4.193510] CPU1: shutdown
[4.262512] CPUZ: shutdown
Are you able to use serial console login? You’d need to post a serial console boot log anyway to figure out what is going on. Without that you’d simply be asked to flash again (though you could clone first).
I attempted to log in using the serial console and succeeded,so what should I do next?
share the /var/log/Xorg.0.log.
[ 260.239] (–) Log file renamed from “/var/log/Xorg.pid-23576.log” to “/var/ll
og/Xorg.0.log”
[ 260.240]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 260.240] X Protocol Version 11, Revision 0
[ 260.240] Build Operating System: Linux 5.4.0-121-generic aarch64 Ubuntu
[ 260.240] Current Operating System: Linux nvidia-desktop 4.9.299-tegra #1 SMPP
PREEMPT Tue Nov 22 09:24:30 PST 2022 aarch64
[ 260.240] Kernel command line: console=ttyS0,115200 androidboot.presilicon=trr
ue firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype==
ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000
gpt rootfs.slot_suffix= tegra_fbmem2=0x800000@0x96088000 lut_mem2=0x2008@0x960855
000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend bb
oot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x1000
00@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw roo
otwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnamm
es=0 isolcpus=1-2
[ 260.240] Build Date: 07 July 2022 05:16:29PM
[ 260.240] xorg-server 2:1.19.6-1ubuntu4.11 (For technical support please see
Enterprise open source support | Ubuntu)
[ 260.240] Current version of pixman: 0.34.0
“/var/log/Xorg.0.log” 168L, 10836C
full log please…
[   245.197] (--) Log file renamed from "/var/log/Xorg.pid-21886.log" to "/var/l
og/Xorg.0.log"
[   245.198]
[   245.198] X Protocol Version 11, Revision 0
[   245.198] Build Operating System: Linux 5.4.0-121-generic aarch64 Ubuntu
[   245.198] Current Operating System: Linux nvidia-desktop 4.9.299-tegra #1 SMP
[   245.198] Kernel command line: console=ttyS0,115200 androidboot.presilicon=tr
es=0 isolcpus=1-2
[   245.198] Build Date: 07 July 2022  05:16:29PM
[   245.198] xorg-server 2:1.19.6-1ubuntu4.11 (For technical support please see
http://www.ubuntu.com/support)
[   245.198] Current version of pixman: 0.34.0
[   245.198]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[   245.198] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   245.198] (==) Log file: "/var/log/Xorg.0.log", Time: Thu May 11 18:07:03 202
3
[   245.199] (==) Using config file: "/etc/X11/xorg.conf"
[   245.199] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   245.199] (==) No Layout section.  Using the first Screen section.
[   245.199] (==) No screen section available. Using defaults.
[   245.199] (**) |-->Screen "Default Screen Section" (0)
[   245.199] (**) |   |-->Monitor "<default monitor>"
[   245.199] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[   245.199] (**) |   |-->Device "Tegra0"
[   245.200] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[   245.200] (==) Automatically adding devices
[   245.200] (==) Automatically enabling devices
[   245.200] (==) Automatically adding GPU devices
[   245.200] (==) Automatically binding GPU devices
[   245.200] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   245.200] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   245.200]    Entry deleted from font path.
[   245.200] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   245.200] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   245.200] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   245.200] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   245.200] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/Type1,
        built-ins
[   245.200] (==) ModulePath set to "/usr/lib/xorg/modules"
[   245.200] (II) The server relies on udev to provide the list of input devices
        If no devices become available, reconfigure udev or disable AutoAddDevic
es.
[   245.200] (II) Loader magic: 0x557bf01010
[   245.200] (II) Module ABI versions:
[   245.200]    X.Org ANSI C Emulation: 0.4
[   245.200]    X.Org Video Driver: 23.0
[   245.200]    X.Org XInput driver : 24.1
[   245.200]    X.Org Server Extension : 10.0
[   245.201] (++) using VT number 1
[   245.207] (II) systemd-logind: took control of session /org/freedesktop/login
1/session/c504
[   245.208] (II) no primary bus or device found
[   245.208] (WW) "dri" will not be loaded unless you've specified it to be load
ed elsewhere.
[   245.208] (II) "glx" will be loaded by default.
[   245.208] (II) LoadModule: "extmod"
[   245.208] (II) Module "extmod" already built-in
[   245.208] (II) LoadModule: "glx"
[   245.208] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   245.211] (II) Module glx: vendor="X.Org Foundation"
[   245.211]    compiled for 1.19.6, module version = 1.0.0
[   245.211]    ABI class: X.Org Server Extension, version 10.0
[   245.211] (II) LoadModule: "nvidia"
[   245.211] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   245.213] (II) Module nvidia: vendor="NVIDIA Corporation"
[   245.213]    compiled for 4.0.2, module version = 1.0.0
[   245.213]    Module class: X.Org Video Driver
[   245.213] (II) NVIDIA dlloader X Driver  32.7.3  Release Build  (integ_stage_
rel)  (buildbrain@mobile-u64-5494-d8000)  Tue Nov 22 09:24:32 PST 2022
[   245.213] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   245.213] (WW) Falling back to old probe method for NVIDIA
[   245.213] (II) Loading sub module "fb"
[   245.213] (II) LoadModule: "fb"
[   245.213] (II) Loading /usr/lib/xorg/modules/libfb.so
[   245.214] (II) Module fb: vendor="X.Org Foundation"
[   245.214]    compiled for 1.19.6, module version = 1.0.0
[   245.214]    ABI class: X.Org ANSI C Emulation, version 0.4
[   245.214] (II) Loading sub module "wfb"
[   245.214] (II) LoadModule: "wfb"
[   245.214] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   245.214] (II) Module wfb: vendor="X.Org Foundation"
[   245.214] (II) Loading sub module "ramdac"
[   245.214] (II) LoadModule: "ramdac"
[   245.214] (II) Module "ramdac" already built-in
[   245.215] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   245.215] (II) NVIDIA(0): Creating default Display subsection in Screen secti
on
        "Default Screen Section" for depth/fbbpp 24/32
[   245.215] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[   245.215] (==) NVIDIA(0): RGB weight 888
[   245.215] (==) NVIDIA(0): Default visual is TrueColor
[   245.215] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   245.215] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[   245.215] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "true"
[   245.215] (**) NVIDIA(0): Enabling 2D acceleration
[   245.215] (II) Loading sub module "glxserver_nvidia"
[   245.215] (II) LoadModule: "glxserver_nvidia"
[   245.216] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.s
o
[   245.225] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[   245.225]    compiled for 4.0.2, module version = 1.0.0
[   245.225]    Module class: X.Org Server Extension
[   245.225] (II) NVIDIA GLX Module  32.7.3  Release Build  (integ_stage_rel)  (
buildbrain@mobile-u64-5494-d8000)  Tue Nov 22 09:23:55 PST 2022
[   245.228] (--) NVIDIA(0): Valid display device(s) on GPU-0 at SoC
[   245.228] (--) NVIDIA(0):     DFP-0
[   245.228] (II) NVIDIA(0): NVIDIA GPU NVIDIA Tegra X2 (nvgpu) (GP10B) at SoC (
GPU-0)
[   245.228] (--) NVIDIA(0): Memory: 8038644 kBytes
[   245.228] (--) NVIDIA(0): VideoBIOS:
[   245.229] (==) NVIDIA(0):
[   245.229] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-a
uto-select"
[   245.229] (==) NVIDIA(0):     will be used as the requested mode.
[   245.229] (--) NVIDIA(0): No enabled display devices found; starting anyway b
ecause
[   245.229] (--) NVIDIA(0):     AllowEmptyInitialConfiguration is enabled
[   245.229] (II) NVIDIA(0): Validated MetaModes:
[   245.229] (II) NVIDIA(0):     "NULL"
[   245.229] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[   245.229] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[   245.229] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[   245.229] (--) Depth 24 pixmap format is 32 bpp
[   245.229] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect m
emory
[   245.229] (II) NVIDIA:     access.
[   245.231] (EE) NVIDIA(0): Failed to allocate NVIDIA Error Handler
[   245.231] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; t
he daemon
[   245.231] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[   245.231] (II) NVIDIA(0):     configuration option may not be set correctly.
 When the
[   245.231] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X dr
iver will
[   245.231] (II) NVIDIA(0):     try to use it to receive ACPI event notificatio
ns.  For
[   245.231] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[   245.231] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Ap
pendix B: X
[   245.231] (II) NVIDIA(0):     Config Options in the README.
[   245.259] (II) NVIDIA(0): Setting mode "NULL"
[   245.262] (==) NVIDIA(0): Disabling shared memory pixmaps
[   245.262] (==) NVIDIA(0): Backing store enabled
[   245.262] (==) NVIDIA(0): Silken mouse enabled
[   245.262] (==) NVIDIA(0): DPMS enabled
[   245.263] (II) Loading sub module "dri2"
[   245.263] (II) LoadModule: "dri2"
[   245.263] (II) Module "dri2" already built-in
[   245.263] (II) NVIDIA(0): [DRI2] Setup complete
[   245.263] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[   245.263] (--) RandR disabled
[   245.268] (II) SELinux: Disabled on system
[   245.269] (II) Initializing extension GLX
[   245.269] (II) Indirect GLX disabled.
[   245.310] (EE) Error compiling keymap (server-0) executing '"/usr/bin/xkbcomp
" -w 1 "-R/usr/share/X11/xkb" -xkm "-" -em1 "The XKEYBOARD keymap compiler (xkbc
omp) reports:" -emp "> " -eml "Errors from xkbcomp are not fatal to the X server
" "/tmp/server-0.xkm"'
[   245.310] (EE) XKB: Couldn't compile keymap
[   245.310] (EE) XKB: Failed to load keymap. Loading default keymap instead.
[   245.336] (EE) Error compiling keymap (server-0) executing '"/usr/bin/xkbcomp
[   245.336] (EE) XKB: Couldn't compile keymap
[   245.336] XKB: Failed to compile keymap
[   245.336] Keyboard initialization failed. This could be a missing or incorrec
t setup of xkeyboard-config.
[   245.336] (EE)
Fatal server error:
[   245.337] (EE) Failed to activate virtual core keyboard: 2(EE)
[   245.337] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[   245.337] (EE) Please also check the log file at "/var/log/Xorg.0.log" for ad
ditional information.
[   245.337] (EE)
[   245.340] (EE) Server terminated with error (1). Closing log file.
looks like the a upstream ubuntu issue that keymap is gone.
Probably some files are missing or corrupted. This is not NV issue. Please try to reflash the board.
Or other user may share their experience.
[ 245.310] (EE) XKB: Couldn’t compile keymap
[ 245.336] (EE) Error compiling keymap (server-0) executing ‘"/usr/bin/xkbcomp
" -w 1 “-R/usr/share/X11/xkb” -xkm “-” -em1 “The XKEYBOARD keymap compiler (xkbc
omp) reports:” -emp "> " -eml "Errors from xkbcomp are not fatal to the X server
" “/tmp/server-0.xkm”’
Okay, I tried to clean up my space. It was a previously automated program that used too much memory and was unable to start due to insufficient space. It has now been resolved
