Jetson TX2 + carrier board could flashed OS successfully ,but could not be startup
My jetson TX2 + carrier board has suffered an unexpected power outage,so the carrier board maybe wrong,but I don’t know where is the problem. This faulty carrier board could take the TX2 core module into recover mode , and flash the OS image normally. But when it turned power on , it could not startup (or boot) the core module. The CR1 and CR2 LED will lighting a short moment and turn off.
the TX2 core module is normal and works fine when plugged into another normal carrier board.
So I want to know what happened to this carrier board and how to fixing it or how to check it to find the problem?
Thanks for your any suggestions!
The following appendix information is the TX2 carrier board serial output when it is turned on:
[0000.233] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mob)
[0000.242] I> Boot-device: eMMC
[0000.249] I> sdmmc bdev is already initialized
[0000.254] I> pmic: reset reason (nverc)        : 0x40
[0000.287] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.307] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.313] W> No valid slot number is found in scratch register
[0000.318] W> Return default slot: _a
[0000.322] I> A/B: bin_type (16) slot 0
[0000.326] I> Loading partition bpmp-fw at 0xd7800000
[0000.330] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.336] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.361] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.366] W> No valid slot number is found in scratch register
[0000.372] W> Return default slot: _a
[0000.375] I> A/B: bin_type (17) slot 0
[0000.379] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.384] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.390] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.416] I> Binary(17) of size 617520 is loaded @ 0xd7969200
[0000.649] I> Loading SCE-FW ...
[0000.652] W> No valid slot number is found in scratch register
[0000.658] W> Return default slot: _a
[0000.661] I> A/B: bin_type (12) slot 0
[0000.665] I> Loading partition sce-fw at 0xd7300000
[0000.670] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.675] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.694] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.700] I> Init SCE
[0000.702] I> Loading APE-FW ...
[0000.705] W> No valid slot number is found in scratch register
[0000.711] W> Return default slot: _a
[0000.714] I> A/B: bin_type (11) slot 0
[0000.718] I> Loading partition adsp-fw at 0xd7400000
[0000.723] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.728] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.747] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.753] I> Copy BTCM section
[0000.756] W> No valid slot number is found in scratch register
[0000.762] W> Return default slot: _a
[0000.765] I> A/B: bin_type (13) slot 0
[0000.769] I> Loading partition cpu-bootloader at 0x96000000
[0000.774] I> Reading two headers - addr:0x96000000 blocks:1
[0000.780] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.801] I> Binary(13) of size 309648 is loaded @ 0x96000000
[0000.807] W> No valid slot number is found in scratch register
[0000.813] W> Return default slot: _a
[0000.816] I> A/B: bin_type (20) slot 0
[0000.820] I> Loading partition bootloader-dtb at 0x85205400
[0000.825] I> Reading two headers - addr:0x85205400 blocks:1
[0000.831] I> Addr: 0x85205400, start-block: 58742792, num_blocks: 1
[0000.853] I> Binary(20) of size 375488 is loaded @ 0x85205400
[0000.859] W> No valid slot number is found in scratch register
[0000.864] W> Return default slot: _a
[0000.868] I> A/B: bin_type (14) slot 0
[0000.872] I> Loading partition secure-os at 0x85305600
[0000.877] I> Reading two headers - addr:0x85305600 blocks:1
[0000.882] I> Addr: 0x85305600, start-block: 58744840, num_blocks: 1
[0000.905] I> Binary(14) of size 406960 is loaded @ 0x85305600
[0000.912] I> TOS boot-params @ 0x85000000
[0000.916] I> TOS params prepared
[0000.919] I> Loading EKS ...
[0000.922] I> A/B: bin_type (15) slot 0
[0000.926] I> Loading partition eks at 0x85905800
[0000.930] I> Reading two headers - addr:0x85905800 blocks:1
[0000.936] I> Addr: 0x85905800, start-block: 58757128, num_blocks: 1
[0000.954] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.960] I> EKB detected (length: 0x400) @ 0x85905800
[0000.965] I> Copied encrypted keys
[0000.969] I> boot profiler @ 0x275844000
[0000.973] I> boot profiler for TOS @ 0x275844000
[0000.977] I> Unhalting SCE
[0000.980] I> Primary Memory Start:80000000 Size:70000000
[0000.985] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.992] I> MB2(TBoot-BPMP) done
NOTICE:  BL31: v1.3(release):f9bf1e1
NOTICE:  BL31: Built : 21:07:06, Jun  8 2023
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.366] I> Welcome to Cboot
[0001.368] I> Cboot Version: t186-8828c893
[0001.372] I> CPU-BL Params @ 0x275800000
[0001.376] I>  0) Base:0x00000000 Size:0x00000000
[0001.380] I>  1) Base:0x277f00000 Size:0x00100000
[0001.385] I>  2) Base:0x277e00000 Size:0x00100000
[0001.389] I>  3) Base:0x277d00000 Size:0x00100000
[0001.394] I>  4) Base:0x277c00000 Size:0x00100000
[0001.398] I>  5) Base:0x277b00000 Size:0x00100000
[0001.403] I>  6) Base:0x277800000 Size:0x00200000
[0001.407] I>  7) Base:0x277400000 Size:0x00400000
[0001.412] I>  8) Base:0x277a00000 Size:0x00100000
[0001.417] I>  9) Base:0x277300000 Size:0x00100000
[0001.421] I> 10) Base:0x276800000 Size:0x00800000
[0001.426] I> 11) Base:0x30000000 Size:0x00040000
[0001.430] I> 12) Base:0xf0000000 Size:0x00100000
[0001.434] I> 13) Base:0x30040000 Size:0x00001000
[0001.439] I> 14) Base:0x30048000 Size:0x00001000
[0001.443] I> 15) Base:0x30049000 Size:0x00001000
[0001.448] I> 16) Base:0x3004a000 Size:0x00001000
[0001.452] I> 17) Base:0x3004b000 Size:0x00001000
[0001.457] I> 18) Base:0x3004c000 Size:0x00001000
[0001.461] I> 19) Base:0x3004d000 Size:0x00001000
[0001.465] I> 20) Base:0x3004e000 Size:0x00001000
[0001.470] I> 21) Base:0x3004f000 Size:0x00001000
[0001.474] I> 22) Base:0x00000000 Size:0x00000000
[0001.479] I> 23) Base:0xf0100000 Size:0x00010000
[0001.483] I> 24) Base:0x00000000 Size:0x00000000
[0001.488] I> 25) Base:0x00000000 Size:0x00000000
[0001.492] I> 26) Base:0x00000000 Size:0x00000000
[0001.496] I> 27) Base:0x00000000 Size:0x00000000
[0001.501] I> 28) Base:0x84400000 Size:0x00400000
[0001.505] I> 29) Base:0x30000000 Size:0x00010000
[0001.510] I> 30) Base:0x278000000 Size:0x08000000
[0001.514] I> 31) Base:0x00000000 Size:0x00000000
[0001.519] I> 32) Base:0x276000000 Size:0x00600000
[0001.523] I> 33) Base:0x80000000 Size:0x70000000
[0001.528] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.532] I> 35) Base:0x00000000 Size:0x00000000
[0001.537] I> 36) Base:0x00000000 Size:0x00000000
[0001.541] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.546] I> 38) Base:0x84000000 Size:0x00400000
[0001.550] I> 39) Base:0x96000000 Size:0x02000000
[0001.554] I> 40) Base:0x85000000 Size:0x01200000
[0001.559] I> 41) Base:0x275800000 Size:0x00500000
[0001.563] I> 42) Base:0x00000000 Size:0x00000000
[0001.568] I> 43) Base:0x00000000 Size:0x00000000
[0001.572] GIC-SPI Target CPU: 4
[0001.576] Interrupts Init done
[0001.579] calling constructors
[0001.582] initializing heap
[0001.585] initializing threads
[0001.588] initializing timers
[0001.591] creating bootstrap completion thread
[0001.596] top of bootstrap2()
[0001.599] CPU: ARM Cortex A57
[0001.602] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.607] initializing platform
[0001.610] I> Bl_dtb @0x85205400
[0001.613] I> gpio framework initialized
[0001.620] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' drir
[0001.630] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon'r
[0001.637] I> GPIO framework and drivers are initialized.
[0001.643] I> Boot-device: eMMC
[0001.650] I> sdmmc bdev is already initialized
[0001.680] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.698] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.704] W> opt-in fuse is not set, skip fuse_burning
[0001.708] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.714] W> No valid slot number is found in scratch register
[0001.720] W> Return default slot: _a
[0001.729] I> A/B: bin_type (21) slot 0
[0001.733] I> Loading kernel-dtb from partition
[0001.737] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.754] I> Kernel_dtb @0x80000000
[0001.758] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.768] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.775] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.784] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.795] I> fixed regulator driver initialized
[0001.828] I> register 'maxim' power off handle
[0001.834] I> virtual i2c enabled
[0001.837] I> registered 'maxim,max77620' pmic
[0001.841] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.855] E> failed to read label property for node 324868: 13
[0001.864] E> failed to read reg property for node 324964: 13
[0001.872] E> failed to read reg property for node 325016: 13
[0001.880] E> failed to read label property for node 325100: 13
[0001.889] E> failed to read label property for node 325168: 13
[0001.897] E> failed to read reg property for node 325236: 13
[0001.905] E> failed to read reg property for node 325308: 13
[0001.916] I> Find /i2c@c250000's alias i2c7
[0001.920] I> Reading eeprom i2c=7 address=0x50
[0001.949] I> Device at /i2c@c250000:0x50
[0001.953] I> Reading eeprom i2c=7 address=0x57
[0001.981] I> Device at /i2c@c250000:0x57
[0001.986] I> Find /i2c@c240000's alias i2c1
[0001.990] I> Reading eeprom i2c=1 address=0x51
[0001.995] E> I2C: slave not found in slaves.
[0001.999] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.007] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.013] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.022] E> eeprom: Retry to read I2C slave device.
[0002.027] E> I2C: slave not found in slaves.
[0002.031] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.039] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.045] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.054] E> eeprom: Failed to read I2C slave device
[0002.059] I> Eeprom read failed 0x3526070d
[0002.064] I> Find /i2c@3160000's alias i2c0
[0002.068] I> Reading eeprom i2c=0 address=0x50
[0002.072] E> I2C: slave not found in slaves.
[0002.076] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0002.084] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.090] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0002.099] E> eeprom: Failed to read I2C slave device
[0002.104] I> Eeprom read failed 0x3526070d
[0002.109] I> Find /i2c@3180000's alias i2c2
[0002.113] I> Reading eeprom i2c=2 address=0x54
[0002.117] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.123] E> I2C: Condition bus clear could not meet.
[0002.128] E> I2C: Failed to clear bus for instance 2.
[0002.133] E> I2C: Failed to clear bus for instance 2.
[0002.138] E> I2C_DEV: Failed to initialize instance 2.
[0002.143] E> eeprom: Can't get handle to eeprom device @168
[0002.148] I> Disabling gpio chip_id = 2, gpio pin = 9
請把你用另一塊carrier board可以正常開機的log貼上來
還有log麻煩這樣子貼
這是log
這是log
這是log
不然非常難閱讀
this following information is normal carrier board and Tx2 core module output:
[0000.252] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mob)
[0000.260] I> Boot-device: eMMC
[0000.268] I> sdmmc bdev is already initialized
[0000.272] I> pmic: reset reason (nverc)        : 0x40
[0000.305] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.325] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.331] W> No valid slot number is found in scratch register
[0000.337] W> Return default slot: _a
[0000.340] I> A/B: bin_type (16) slot 0
[0000.344] I> Loading partition bpmp-fw at 0xd7800000
[0000.349] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.354] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.379] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.385] W> No valid slot number is found in scratch register
[0000.390] W> Return default slot: _a
[0000.394] I> A/B: bin_type (17) slot 0
[0000.397] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.402] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.408] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.434] I> Binary(17) of size 617520 is loaded @ 0xd7969200
[0000.667] I> Loading SCE-FW ...
[0000.670] W> No valid slot number is found in scratch register
[0000.676] W> Return default slot: _a
[0000.679] I> A/B: bin_type (12) slot 0
[0000.683] I> Loading partition sce-fw at 0xd7300000
[0000.688] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.693] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.712] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.718] I> Init SCE
[0000.721] I> Loading APE-FW ...
[0000.724] W> No valid slot number is found in scratch register
[0000.729] W> Return default slot: _a
[0000.733] I> A/B: bin_type (11) slot 0
[0000.736] I> Loading partition adsp-fw at 0xd7400000
[0000.741] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.747] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.766] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.771] I> Copy BTCM section
[0000.774] W> No valid slot number is found in scratch register
[0000.780] W> Return default slot: _a
[0000.783] I> A/B: bin_type (13) slot 0
[0000.787] I> Loading partition cpu-bootloader at 0x96000000
[0000.792] I> Reading two headers - addr:0x96000000 blocks:1
[0000.798] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.819] I> Binary(13) of size 309648 is loaded @ 0x96000000
[0000.825] W> No valid slot number is found in scratch register
[0000.831] W> Return default slot: _a
[0000.834] I> A/B: bin_type (20) slot 0
[0000.838] I> Loading partition bootloader-dtb at 0x85205400
[0000.843] I> Reading two headers - addr:0x85205400 blocks:1
[0000.849] I> Addr: 0x85205400, start-block: 58742792, num_blocks: 1
[0000.871] I> Binary(20) of size 375488 is loaded @ 0x85205400
[0000.877] W> No valid slot number is found in scratch register
[0000.883] W> Return default slot: _a
[0000.886] I> A/B: bin_type (14) slot 0
[0000.890] I> Loading partition secure-os at 0x85305600
[0000.895] I> Reading two headers - addr:0x85305600 blocks:1
[0000.900] I> Addr: 0x85305600, start-block: 58744840, num_blocks: 1
[0000.923] I> Binary(14) of size 406960 is loaded @ 0x85305600
[0000.930] I> TOS boot-params @ 0x85000000
[0000.934] I> TOS params prepared
[0000.938] I> Loading EKS ...
[0000.940] I> A/B: bin_type (15) slot 0
[0000.944] I> Loading partition eks at 0x85905800
[0000.948] I> Reading two headers - addr:0x85905800 blocks:1
[0000.954] I> Addr: 0x85905800, start-block: 58757128, num_blocks: 1
[0000.973] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.978] I> EKB detected (length: 0x400) @ 0x85905800
[0000.983] I> Copied encrypted keys
[0000.987] I> boot profiler @ 0x275844000
[0000.991] I> boot profiler for TOS @ 0x275844000
[0000.996] I> Unhalting SCE
[0000.998] I> Primary Memory Start:80000000 Size:70000000
[0001.003] I> Extended Memory Start:f0110000 Size:1856f0000
[0001.010] I> MB2(TBoot-BPMP) done
[0001.384] I> Welcome to Cboot
[0001.387] I> Cboot Version: t186-8828c893
[0001.391] I> CPU-BL Params @ 0x275800000
[0001.394] I>  0) Base:0x00000000 Size:0x00000000
[0001.399] I>  1) Base:0x277f00000 Size:0x00100000
[0001.403] I>  2) Base:0x277e00000 Size:0x00100000
[0001.408] I>  3) Base:0x277d00000 Size:0x00100000
[0001.412] I>  4) Base:0x277c00000 Size:0x00100000
[0001.417] I>  5) Base:0x277b00000 Size:0x00100000
[0001.421] I>  6) Base:0x277800000 Size:0x00200000
[0001.426] I>  7) Base:0x277400000 Size:0x00400000
[0001.430] I>  8) Base:0x277a00000 Size:0x00100000
[0001.435] I>  9) Base:0x277300000 Size:0x00100000
[0001.440] I> 10) Base:0x276800000 Size:0x00800000
[0001.444] I> 11) Base:0x30000000 Size:0x00040000
[0001.448] I> 12) Base:0xf0000000 Size:0x00100000
[0001.453] I> 13) Base:0x30040000 Size:0x00001000
[0001.457] I> 14) Base:0x30048000 Size:0x00001000
[0001.462] I> 15) Base:0x30049000 Size:0x00001000
[0001.466] I> 16) Base:0x3004a000 Size:0x00001000
[0001.471] I> 17) Base:0x3004b000 Size:0x00001000
[0001.475] I> 18) Base:0x3004c000 Size:0x00001000
[0001.479] I> 19) Base:0x3004d000 Size:0x00001000
[0001.484] I> 20) Base:0x3004e000 Size:0x00001000
[0001.488] I> 21) Base:0x3004f000 Size:0x00001000
[0001.493] I> 22) Base:0x00000000 Size:0x00000000
[0001.497] I> 23) Base:0xf0100000 Size:0x00010000
[0001.502] I> 24) Base:0x00000000 Size:0x00000000
[0001.506] I> 25) Base:0x00000000 Size:0x00000000
[0001.510] I> 26) Base:0x00000000 Size:0x00000000
[0001.515] I> 27) Base:0x00000000 Size:0x00000000
[0001.519] I> 28) Base:0x84400000 Size:0x00400000
[0001.524] I> 29) Base:0x30000000 Size:0x00010000
[0001.528] I> 30) Base:0x278000000 Size:0x08000000
[0001.533] I> 31) Base:0x00000000 Size:0x00000000
[0001.537] I> 32) Base:0x276000000 Size:0x00600000
[0001.542] I> 33) Base:0x80000000 Size:0x70000000
[0001.546] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.551] I> 35) Base:0x00000000 Size:0x00000000
[0001.555] I> 36) Base:0x00000000 Size:0x00000000
[0001.560] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.564] I> 38) Base:0x84000000 Size:0x00400000
[0001.568] I> 39) Base:0x96000000 Size:0x02000000
[0001.573] I> 40) Base:0x85000000 Size:0x01200000
[0001.577] I> 41) Base:0x275800000 Size:0x00500000
[0001.582] I> 42) Base:0x00000000 Size:0x00000000
[0001.586] I> 43) Base:0x00000000 Size:0x00000000
[0001.591] GIC-SPI Target CPU: 4
[0001.594] Interrupts Init done
[0001.597] calling constructors
[0001.600] initializing heap
[0001.603] initializing threads
[0001.606] initializing timers
[0001.609] creating bootstrap completion thread
[0001.614] top of bootstrap2()
[0001.617] CPU: ARM Cortex A57
[0001.620] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.625] initializing platform
[0001.629] I> Bl_dtb @0x85205400
[0001.632] I> gpio framework initialized
[0001.638] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' drir
[0001.648] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon'r
[0001.656] I> GPIO framework and drivers are initialized.
[0001.661] I> Boot-device: eMMC
[0001.668] I> sdmmc bdev is already initialized
[0001.699] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.717] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.722] W> opt-in fuse is not set, skip fuse_burning
[0001.727] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.733] W> No valid slot number is found in scratch register
[0001.738] W> Return default slot: _a
[0001.748] I> A/B: bin_type (21) slot 0
[0001.751] I> Loading kernel-dtb from partition
[0001.756] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.773] I> Kernel_dtb @0x80000000
[0001.776] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.787] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.794] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.803] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.813] I> fixed regulator driver initialized
[0001.846] I> register 'maxim' power off handle
[0001.852] I> virtual i2c enabled
[0001.855] I> registered 'maxim,max77620' pmic
[0001.860] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.874] E> failed to read label property for node 324868: 13
[0001.882] E> failed to read reg property for node 324964: 13
[0001.891] E> failed to read reg property for node 325016: 13
[0001.899] E> failed to read label property for node 325100: 13
[0001.907] E> failed to read label property for node 325168: 13
[0001.916] E> failed to read reg property for node 325236: 13
[0001.924] E> failed to read reg property for node 325308: 13
[0001.934] I> Find /i2c@c250000's alias i2c7
[0001.938] I> Reading eeprom i2c=7 address=0x50
[0001.967] I> Device at /i2c@c250000:0x50
[0001.971] I> Reading eeprom i2c=7 address=0x57
[0002.000] I> Device at /i2c@c250000:0x57
[0002.004] I> Find /i2c@c240000's alias i2c1
[0002.008] I> Reading eeprom i2c=1 address=0x51
[0002.013] E> I2C: slave not found in slaves.
[0002.018] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.025] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.031] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.041] E> eeprom: Retry to read I2C slave device.
[0002.046] E> I2C: slave not found in slaves.
[0002.050] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.057] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.063] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.073] E> eeprom: Failed to read I2C slave device
[0002.077] I> Eeprom read failed 0x3526070d
[0002.082] I> Find /i2c@3160000's alias i2c0
[0002.086] I> Reading eeprom i2c=0 address=0x50
[0002.090] E> I2C: slave not found in slaves.
[0002.094] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0002.102] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.108] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0002.118] E> eeprom: Failed to read I2C slave device
[0002.122] I> Eeprom read failed 0x3526070d
[0002.127] I> Find /i2c@3180000's alias i2c2
[0002.131] I> Reading eeprom i2c=2 address=0x54
[0002.135] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.166] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.171] I> Device at /i2c@3180000:0x54
[0002.175] I> Reading eeprom i2c=2 address=0x57
[0002.179] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.185] E> I2C: slave not found in slaves.
[0002.189] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0002.197] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.203] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0002.212] E> eeprom: Failed to read I2C slave device
[0002.217] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.222] I> Eeprom read failed 0x00000000
[0002.226] I> create_pm_ids: id: 3310-1000-B02-E, len: 15
[0002.231] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.242] I> create_pm_ids: id: 2597-0000-900-E, len: 15
[0002.247] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.258] I> create_pm_ids: id: 3326-1000-000-M, len: 15
[0002.263] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:f3
[0002.298] I> enabling 'vdd-hdmi' regulator
[0002.314] I> regulator 'vdd-hdmi' already enabled
[0002.318] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.325] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.334] E> cannot find any other nvdisp nodes
[0002.338] E> no valid display unit config found in dtb
[0002.344] W> display init failed
[0002.347] initializing target
[0002.350] calling apps_init()
[0002.353] starting app kernel_boot_app
[0002.375] I> found decompressor handler: lz4-legacy
[0002.380] I> decompressing BMP blob ...
[0002.452] I> Kernel type = Normal
[0002.455] I> ########## Fixed storage boot ##########
[0002.460] I> Loading kernel-bootctrl from partition
[0002.465] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.479] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.486] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.493] W> No valid slot number is found in scratch register
[0002.499] W> Return default slot: _a
[0002.502] I> A/B: bin_type (24) slot 0
[0002.518] I> Boot image size read from image header: 990e5
[0002.523] I> Boot image load address: 0x80400000
[0002.528] I> Loading kernel from partition
[0002.532] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.491] I> Validate kernel ...
[0003.494] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.502] I> Decrypt the buffer ... [0003.506] W> tegrabl_decrypt_block: fuse .
[0003.515] I> done
[0003.516] I> Checking boot.img header magic ... [0003.521] I> [OK]
[0003.522] I> kernel-dtb is already loaded
[0003.526] I> Validate kernel-dtb ...
[0003.529] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.537] I> Decrypt the buffer ... [0003.541] W> tegrabl_decrypt_block: fuse .
[0003.549] I> done
[0003.551] I> Kernel hdr @0x80400000
[0003.555] I> Kernel dtb @0x80000000
[0003.558] I> decompressor handler not found
[0003.562] I> Copying kernel image (626917 bytes) from 0x80400800 to 0x80600000e
[0003.571] I> Move ramdisk (len: 0) from 0x8049a000 to 0x947d0000
[0003.579] I> Updated bpmp info to DTB
[0003.585] I> Ramdisk: Base: 0x947d0000; Size: 0x0
[0003.589] I> Updated initrd info to DTB
[0003.593] W> WARN: Fail to override "console=none" in commandline
[0003.599] I> Active rootfs suffix:
[0003.602] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.609] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.617] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.624] I> disabled_core_mask: 0xffffff0c
[0003.628] W> No valid slot number is found in scratch register
[0003.633] W> Return default slot: _a
[0003.637] I> Active slot suffix:
[0003.640] I> add_boot_slot_suffix: slot_suffix =
[0003.644] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true f
[0003.693] I> Updated bootarg info to DTB
[0003.697] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:c4:b1:f7
[0003.703] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:c4:b1:f8
[0003.709] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:c4:b1:f9
[0003.716] E> Found no plugin manager ids in source DT
[0003.720] W> Add plugin manager ids from board info
[0003.725] W> "plugin-manager" doesn't exist, creating
[0003.730] W> "ids" doesn't exist, creating
[0003.734] W> "connection" doesn't exist, creating
[0003.739] W> "configs" doesn't exist, creating
[0003.743] I> create_pm_ids: id: 3310-1000-B02-E, len: 15
[0003.748] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0003.759] I> create_pm_ids: id: 2597-0000-900-E, len: 15
[0003.764] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0003.775] I> create_pm_ids: id: 3326-1000-000-M, len: 15
[0003.780] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:f3
[0003.791] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0003.798] W> "i2c@c250000" doesn't exist, creating
[0003.803] W> "module@0x50" doesn't exist, creating
[0003.808] I> Adding plugin-manager/ids/2597-0000-900=/i2c@c250000:module@0x57
[0003.815] W> "module@0x57" doesn't exist, creating
[0003.820] I> Adding plugin-manager/ids/3326-1000-000=/i2c@3180000:module@0x54
[0003.827] W> "i2c@3180000" doesn't exist, creating
[0003.832] W> "module@0x54" doesn't exist, creating
[0003.839] I> Adding plugin-manager/ids/3310-1000-B02-E
[0003.846] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.852] I> Adding plugin-manager/configs/3310-power-config 00
[0003.858] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.863] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.869] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.875] I> Adding plugin-manager/configs/3310-display-config 00
[0003.881] I> Adding plugin-manager/cvm
[0003.885] W> "chip-id" doesn't exist, creating
[0003.890] I> Adding plugin-manager/chip-id/A02P
[0003.894] W> "odm-data" doesn't exist, creating
[0003.899] I> Adding /chosen/plugin-manager/odm-data
[0003.908] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.914] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.920] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.926] I> added [base:0x276600000, size:0x200000] to /memory
[0003.932] I> added [base:0x277000000, size:0x200000] to /memory
[0003.937] I> Updated memory info to DTB
[0003.942] W> add_disp_param: failed to get display params for du=0
[0003.950] W> "reset" doesn't exist, creating
[0003.954] W> "pmc-reset-reason" doesn't exist, creating
[0003.959] W> "pmic-reset-reason" doesn't exist, creating
[0003.966] I> Adding ecid(0000000164406642180000000d038380) to DT
[0003.971] I> disabled_core_mask: 0xffffff0c
[0003.984] I> Add serial number:0422518007504 as DT property
[0003.993] I> Plugin-manager override starting
[0003.999] I> node /plugin-manager/fragement@0 matches
[0004.009] I> node /plugin-manager/fragement@4 matches
[0004.022] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0004.042] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0004.051] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0004.060] I> node /plugin-manager/fragment-devslp@0 matches
[0004.072] I> node /plugin-manager/fragment-500-pcie-config matches
[0004.087] I> node /plugin-manager/fragment-500-xusb-config matches
[0004.110] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0004.124] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0004.134] I> node /plugin-manager/fragment-p3310-c01 matches
[0004.147] I> node /plugin-manager/fragment-p3310-c03 matches
[0004.190] I> node /plugin-manager/fragment-e3326@0 matches
[0004.271] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0004.298] I> Disable plugin-manager status in FDT
[0004.303] I> Plugin-manager override finished successfully
[0004.308] I> tegrabl_load_kernel_and_dtb: Done
[0004.313] W> tegrabl_display_clear: display is not initialized
[0004.318] W> Boot logo display failed...
[0004.322] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2020.04-g4335beb (Jun 08 2023 - 21:07:09 -0700)
SoC: tegra186
Model: NVIDIA P2771-0000-500
Board: NVIDIA P2771-0000
DRAM:  7.8 GiB
MMC:   sdhci@3400000: 1, sdhci@3460000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:
Warning: ethernet@2490000 using MAC address from ROM
eth0: ethernet@2490000
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
873 bytes read in 20 ms (42 KiB/s)
1:      primary kernel
Retrieving file: /boot/initrd
7238484 bytes read in 198 ms (34.9 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 839 ms (39.5 MiB/s)
append: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/e
## Flattened Device Tree blob at 80000000
   Booting using the fdt blob at 0x80000000
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000080000000, end 0000000080060a5f
copying carveout for /host1x@13e00000/display-hub@15200000/display@15200000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15210000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15220000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5418-d8000) (3
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  185600000
[    0.000000] OF: fdt: - 275e00000 ,  200000
[    0.000000] OF: fdt: - 276600000 ,  200000
[    0.000000] OF: fdt: - 277000000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    1.848007] cgroup: cgroup2: unknown option "nsdelegate"
[    2.872208] using random self ethernet address
[    2.879268] using random host ethernet address
[    3.093779] random: systemd: uninitialized urandom read (16 bytes read)
[    3.103525] random: systemd: uninitialized urandom read (16 bytes read)
[    3.113728] random: systemd: uninitialized urandom read (16 bytes read)
[    3.341677] random: crng init done
[    3.345086] random: 180 urandom warning(s) missed due to ratelimiting
[    3.491951] using random self ethernet address
[    3.509716] using random host ethernet address
[    4.025962] CPU1: shutdown
[    4.107781] CPU2: shutdown
[    5.022201] Bridge firewalling registered
Ubuntu 18.04.6 LTS ubuntu ttyS0
ubuntu login:
你用開步起來的那片底板重燒可以成功嗎?
如果也不行的話大概是硬體有零件壞了
我将一个完好的正常TX2模块安装到这个故障的载板上,也启动不起来。但是这个故障的载板能将任何一个核心模块进入恢复模式,并成功烧录OS镜像。
I take a good, normal TX2 module onto the failed carrier board and it would not boot. However, the failed carrier board can put aother core module into recovery mode and successfully burn the OS image
I can do some hardware check.but I don’t know where or which component and check-point need to be checked.can you tell me some suggestions?
---- Replied Message ----
From | Dave Yu via NVIDIA Developer Forumsnotifications@nvidia.discoursemail.com |
    Date | 04/02/2024 13:46 |
    To | caoshilong2006@163.com |
    Cc | |
    Subject | [NVIDIA Developer Forums] [Jetson & Embedded Systems/Jetson TX2] Jetson TX2 + carrier board could flashed OS successfully ,but could not be startup |
| DaveYYY Moderator
April 2 |
@Trumany
Is there anything the user can check from the hardware side?
Is that custom carrier board? You may need to check all IOs (UART especially) shared b/w module and carrier to make sure the pin status won’t be affected during power on.
carrier board is official board with tx2 core mudule.
From | Trumany via NVIDIA Developer Forumsnotifications@nvidia.discoursemail.com |
    Date | 04/02/2024 16:42 |
    Cc | |
| Trumany Moderator
April 2 |
As said, please check all IOs pin status first.
thanks. I have got it.when I re-plant core module into carrier board,it start work normally.
    Date | 04/02/2024 16:57 |
    Cc | |
| Trumany Moderator
April 2 |
caoshilong2006:
