Jetson tx2 couldn't display when power on, while ssh can connect and control
After I updated software reminded by system, jetson tx2 couldn’t display when power on, while ssh can connect and control. And display error: could not set regulator ocr. What should I do?
May I have more info here
  1. Do you mean the GUI reminds you to update system? What was your last version of jetpack release?
  2. Are you able to share your current dmesg and syslog (var/log/syslog)?
Any update for this topic? If there is no reply, we will close this thread.
Thanks for your answer. I have solved this problem. It main problem caused by the graphic driver.
