Also want to know
Does this panel have its own FB inside?
In your comment #1
we have developed a custom system based on a TX2 Jetson and some weeks ago switched to Jetpack 4.3.
It feels like it is a regression after jetpack4.3… Which release were you using? Did you see correct order in that release?
(1): no, its a FB-less controller. We use <TEGRA_DC_OUT_CONTINUOUS_MODE>.
(2) We always had this problem. We have used jetpack 3.2.1 before, and had the same effect. We also had an other display panel - same resolution, similar controller though- and had the same effect.
With Jetpack 4.5 the issue is still the same. Has anyone any idea how I can debug this further?
