Following the design from “Nvidia Jetson Camera module - Hardware design guide”(https://developer.nvidia.com/embedded/dlc/jetson-camera-module), we have designed a custom board that supports 6 cameras (i2c@0-5) which are behind an I2C mux. A single GPIO expander (i2c@6) is also behind the i2c mux.
We are working on the device tree changes using t18x-common-modules/tegra186-camera-e3333-a00.dtsi as the reference. But the corresponding quill file does not put the gpio expansion node inside the i2c mux. Is this the right way to design the device tree?
i2c@3180000 {
tca6408_21: tca6408@21 {
compatible = "ti,tca6408";
My understanding is that this gpio expansion node should be placed inside an i2c node (i2c@6 in this case)
i2c@3180000 {
tca9548_77: tca9548@77 {
compatible = "nxp,pca9548";
reg = <0x77>;
i2c@6 {
