SDK Manager 1.8.0.10363
JetPack 4.6.2 r32.7
Just getting started with an old TX2 developer kit that’s never been used. The host system (a physical server) is running ubuntu 18.04.6 and the TX2 has been flashed via sdkmanager, however the subsequent verification of packages failed because the TX2 did not have Internet access. In order to provide access I needed to change the IP which I did via the dhcp server and then rebooting the TX2. It comes up fine and now has Internet access.
In retrying the verification, now the problem is due to errors in certificate verification for the nvidia repositories. Assuming that once the system had received all of its packages the proper keyrings would be in place, so as a temporary hack I added the allow-insecure=yes option to the apt sources file on the TX2:
# sed -i.orig -e 's/deb https/deb [ allow-insecure=yes ] https/' /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
# grep -v '^#' /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
deb [ allow-insecure=yes ] https://repo.download.nvidia.com/jetson/common r32.7 main
deb [ allow-insecure=yes ] https://repo.download.nvidia.com/jetson/t186 r32.7 main
This resolves some of the errors, but now I see that there are additional nvidia repositories with the same problem, however I don’t find apt sources for these:
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r32.7/main/binary-arm64/Packages Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 96.17.149.8 443]
E: Failed to fetch https://repo.download.nvidia.com/jetson/t186/dists/r32.7/main/binary-arm64/Packages Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown. Could not handshake: Error in the certificate verification. [IP: 96.17.149.8 443]
This much fiddling also says to me that I’m fighting someone else’s battles, in other words the problem is farther upstream in the nvidia repositories themselves (I think).
–Larry
The complete output from apt update is as follows
# apt update; echo Status: $?
Ign:1 https://repo.download.nvidia.com/jetson/common r32.7 InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Ign:4 https://repo.download.nvidia.com/jetson/t186 r32.7 InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Ign:6 https://repo.download.nvidia.com/jetson/common r32.7 Release
Hit:7 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Ign:8 https://repo.download.nvidia.com/jetson/t186 r32.7 Release
Ign:9 https://repo.download.nvidia.com/jetson/common r32.7/main all Packages
Ign:10 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 Packages
Ign:11 https://repo.download.nvidia.com/jetson/common r32.7/main Translation-en
Ign:12 https://repo.download.nvidia.com/jetson/common r32.7/main Translation-en_US
Ign:13 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 DEP-11 Metadata
Ign:14 https://repo.download.nvidia.com/jetson/common r32.7/main all DEP-11 Metadata
Ign:15 https://repo.download.nvidia.com/jetson/common r32.7/main DEP-11 48x48 Icons
Ign:16 https://repo.download.nvidia.com/jetson/common r32.7/main DEP-11 64x64 Icons
Ign:17 https://repo.download.nvidia.com/jetson/t186 r32.7/main arm64 Packages
Ign:18 https://repo.download.nvidia.com/jetson/t186 r32.7/main all Packages
Ign:19 https://repo.download.nvidia.com/jetson/t186 r32.7/main Translation-en_US
Ign:20 https://repo.download.nvidia.com/jetson/t186 r32.7/main Translation-en
Ign:21 https://repo.download.nvidia.com/jetson/t186 r32.7/main all DEP-11 Metadata
Ign:22 https://repo.download.nvidia.com/jetson/t186 r32.7/main arm64 DEP-11 Metadata
Ign:23 https://repo.download.nvidia.com/jetson/t186 r32.7/main DEP-11 48x48 Icons
Ign:24 https://repo.download.nvidia.com/jetson/t186 r32.7/main DEP-11 64x64 Icons
Err:10 https://repo.download.nvidia.com/jetson/common r32.7/main arm64 Packages
Err:17 https://repo.download.nvidia.com/jetson/t186 r32.7/main arm64 Packages
Reading package lists... Done
W: The repository 'https://repo.download.nvidia.com/jetson/common r32.7 Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'https://repo.download.nvidia.com/jetson/t186 r32.7 Release' does not have a Release file.
E: Some index files failed to download. They have been ignored, or old ones used instead.
Status: 100
