I bought the Jetson TX2 Development Board a while ago and right now I’m trying to connect a CAN transceiver to the TX2.
The problem I’m having is that right now: I have found which PINs to use for the CAN transceiver (D19 & D18), but I don’t find a Pinout or Pin description so that I know where to actually connect the pins physically.
Is there any PDF or other documents out there that describe the pinout ?
Thanks already.
