Jetson TX2 Gstreamer Hardware Decoder GPU Usage Problem
Hello.
My English is not that great.
I created a gstreamer pipeline including omxh264dec.
But GPU is not used, only CPU is used.
why can’t use hardware decorder?
pipeline = gst_pipeline_new (“rtsp video player”);
source = gst_element_factory_make (“rtspsrc”, “rtsp-source”);
depay = gst_element_factory_make (“rtph264depay”, “depay”);
parse = gst_element_factory_make (“h264parse”, NULL);
decode = gst_element_factory_make (“omxh264dec”, NULL);
sink = gst_element_factory_make (“appsink”, NULL);
There is independent hardware decode engine called NVDEC. You can check it in sudo tegrastats.
Thank you for answer.
I use jtop. jtop is system monitoring utility for jetson.
I think NVDEC is GPU in jtop. Is that right?
I can see that NVDEC is activated while gstreamer program code is running.
but GPU is almost zero and CPUs is between 30% and 50%.
I use new-sample signal and callback function to get a raw yuv data.
Can it be a problem if I don’t add “video/x-raw” to pipeline?
No, it is independent hardware block. You can check technical reference manual for hardware architecture.
For CPU usage, if you get video/x-raw buffers in appsink, it takes certain CPU loading.
