mesi
August 21, 2019, 8:45am
1
Hi, I am working with Jetson TX2 and ZED Mini camera. I can record videos with hardware encoding, but I can’t stream to a pipe.
Could you help me what’s wrong with this?
gst-launch-1.0 -e v4l2src device=/dev/video1 ! 'video/x-raw,width=2560,height=720,format=(string)YUY2,framerate=15/1' ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! queue ! omxh264enc ! queue ! mux. alsasrc device='hw:2,0' ! voaacenc ! queue ! qtmux name=mux ! filesink location=video.fifo
mesi
August 21, 2019, 9:52am
3
Hi thanks, I will try it, but our partners asked to use pipe. Have you any other idea?
Not sure if ‘pipe’ is supported in gstreamer. You may also consider to use tegra_multmedia_api. It is low-level interface and you can integrate it with other frameworks to complete the implementation.
Document is at https://developer.nvidia.com/embedded/dlc/NVIDIA_Tegra_Linux_MultimediaAPIReference
If you install the whole system via sdkmanager, you will see samples in /usr/src/tegra_multimedia_api/
mesi
August 21, 2019, 1:20pm
5
Thanks, I will see it. I have tried the udpsink, but I got error.
My code is :
gst-launch-1.0 -e v4l2src device=/dev/video1 ! 'video/x-raw,width=2560,height=720,format=(string)YUY2,framerate=15/1' ! queue ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! queue ! omxh264enc ! queue ! mux. alsasrc device='hw:2,0' ! voaacenc ! queue ! qtmux name=mux ! udpsink host=hostIP port=PORT
The error is the following : GST_PAD: could not send sticky events
and after it
Internal data stream error, Streaming Stopped, reason error (-5)
Do you have any idea for that?
Thanks for replying.
The sample pipeline is video only. You may verify video-only case first.
