Hello! so I just got this board and I am having trouble figuring out its IP address. How can I do this?
If it is configured automatically by dhcp, you may look into your dhcp server for logs.
Otherwise, you can connect the serial console and after boot and login try ifconfig to see your jetson IP.
Static IP would be easier in your case, if possible on your network.
