I’ve managed to connect my TX2 Developer Kit ( Ubuntu 18.04 installed with JetPack 4.6.5 ) to my laptop ( Ubuntu 20.04 ) with ethernet cable but neither I can ping or connect via SSH. These are the steps I’ve done so far:
1- Add static IP to my laptop → 192.168.0.16/24
Settings → Network → Wired Connection’s Settings → IPv4 → Select Manual → Fill The Address and Netmask → Apply
2- Add static IP to my TX2 → 192.168.0.10/24
3- Connect with ethernet cable
4- Confirm the IP’s has come on both devices
5- Send ping from both devices but couldn’t send
6- Try to connect with ssh but could’t do it either
Later, I connected both devices on the same Wifi and tried to connect with SSH and succeed.
My question is how to connect SSH with Ethernet cable?
ifconfig
on both devices:
TX2:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.10 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::837:e1d1:b58a:ee04 prefixlen 64 scopeid 0x20
ether X:X:X:X:X:X txqueuelen 1000 (Ethernet)
RX packets 20 bytes 3153 (3.1 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 49 bytes 5328 (5.3 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 41
Laptop:
enp2s0f1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.16 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::9e41:5f43:830f:6fb1 prefixlen 64 scopeid 0x20
ether Y:Y:Y:Y:Y:Y txqueuelen 1000 (Ethernet)
RX packets 109 bytes 19014 (19.0 KB)
TX packets 475 bytes 73599 (73.5 KB)
TX errors 5 dropped 0 overruns 0 carrier 0 collisions 0
EDIT
tcdump
command output’s has added…
Note: I hidden the mac address (X:X:X:X:X:X)
Laptop:
listening on enp2s0f1, link-type EN10MB (Ethernet), capture size 262144 bytes
23:44:36.435550 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830305913 ecr 0,nop,wscale 7], length 0
23:44:37.456088 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830306934 ecr 0,nop,wscale 7], length 0
23:44:39.472016 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830308950 ecr 0,nop,wscale 7], length 0
23:44:41.488014 ARP, Request who-has 192.168.0.10 tell zeobora-Nitro-AN515-42, length 28
23:44:41.488669 ARP, Reply 192.168.0.10 is-at X:X:X:X:X:X (oui Unknown), length 46
23:44:43.536448 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830313014 ecr 0,nop,wscale 7], length 0
23:44:51.728448 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830321206 ecr 0,nop,wscale 7], length 0
23:44:52.076570 IP zeobora-Nitro-AN515-42.39242 > 239.255.255.250.1900: UDP, length 173
23:44:53.080123 IP zeobora-Nitro-AN515-42.39242 > 239.255.255.250.1900: UDP, length 173
23:44:54.080491 IP zeobora-Nitro-AN515-42.39242 > 239.255.255.250.1900: UDP, length 173
23:44:55.081248 IP zeobora-Nitro-AN515-42.39242 > 239.255.255.250.1900: UDP, length 173
23:45:06.788448 IP zeobora-Nitro-AN515-42.mdns > mdns.mcast.net.mdns: 0 [9q] PTR (QM)? _nfs._tcp.local. PTR (QM)? _ipp._tcp.local. PTR (QM)? _ipps._tcp.local. PTR (QM)? _ftp._tcp.local. PTR (QM)? _webdav._tcp.local. PTR (QM)? _webdavs._tcp.local. PTR (QM)? _sftp-ssh._tcp.local. PTR (QM)? _smb._tcp.local. PTR (QM)? _afpovertcp._tcp.local. (141)
23:45:07.856020 IP zeobora-Nitro-AN515-42.48772 > 192.168.0.10.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830337334 ecr 0,nop,wscale 7], length 0
TX2:
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
23:44:37.785101 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830305913 ecr 0,nop,wscale 7], length 0
23:44:38.805644 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830306934 ecr 0,nop,wscale 7], length 0
23:44:40.821750 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830308950 ecr 0,nop,wscale 7], length 0
23:44:42.837617 ARP, Request who-has ubuntu tell 192.168.0.16, length 46
23:44:42.837816 ARP, Reply ubuntu is-at X:X:X:X:X:X (oui Unknown), length 28
23:44:44.886177 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830313014 ecr 0,nop,wscale 7], length 0
23:44:53.078190 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830321206 ecr 0,nop,wscale 7], length 0
23:44:53.426255 IP 192.168.0.16.39242 > 239.255.255.250.1900: UDP, length 173
23:44:54.429881 IP 192.168.0.16.39242 > 239.255.255.250.1900: UDP, length 173
23:44:55.430212 IP 192.168.0.16.39242 > 239.255.255.250.1900: UDP, length 173
23:44:56.430932 IP 192.168.0.16.39242 > 239.255.255.250.1900: UDP, length 173
23:45:08.138227 IP 192.168.0.16.mdns > mdns.mcast.net.mdns: 0 [9q] PTR (QM)? _nfs._tcp.local. PTR (QM)? _ipp._tcp.local. PTR (QM)? _ipps._tcp.local. PTR (QM)? _ftp._tcp.local. PTR (QM)? _webdav._tcp.local. PTR (QM)? _webdavs._tcp.local. PTR (QM)? _sftp-ssh._tcp.local. PTR (QM)? _smb._tcp.local. PTR (QM)? _afpovertcp._tcp.local. (141)
23:45:09.205729 IP 192.168.0.16.48772 > ubuntu.ssh: Flags [S], seq 1127544129, win 64240, options [mss 1460,sackOK,TS val 3830337334 ecr 0,nop,wscale 7], length 0
