Hi, I got a Jetson TX2 (already configured). After a while when I open it, it stuck on the login page, and it does not respond to the keyboard and mouse.
Is the power indicator LED on your keyboard or mouse still powered on?
Keyboard is powered on, but the mouse is not
Since jetson TX2 devkit only has one USB A port, are you using a usb hub here? Or are you using a custom carrier board?
(any non-NV developer kit is a custom carrier board)
I was switching to plugin the keyboard and mouse back-and-forth to see which will work
If you want us to help dig into why usb does not work, please enable the serial console and dump the dmesg.
Ok, thanks
