We are using Jetson TX2 with tegra-l4t-r32.3.1 kernel.
Test setup:
Router ------------ Netgear Switch ---------------- Nvidia Jetson TX2
In our test scenario, Jetson TX2 gets the network IP address over DHCP or static IP.
Switching between dhcp or static ip is done using systemd-networkd, and works fine most of the time.
But occasionally after switching dhcp to static / static to dhcp , we noticed Jetson TX2 is unable to receive any packets but able to send packets out.
When this issue happens , I could see ethtool reporting mmc_rx_fifo_overflow errors continuously.
eth0 interface TX packet count increase with egress packets , but RX packet count remains constant and don’t even see RX interrupt count changing.
Could you please help us understand the triggers for mmc_rx_fifo_overflow ? I am unable to find any documents detailing the ethernet MAC registers. Is there any known issues Jetson TX2 MAC?
jetson-tx2-dev:/sys/kernel/debug# cat /proc/interrupts | grep qos
35: 10 0 0 0 0 0 GICv2 226 Level ether_qos.common_irq
37: 3067 0 0 0 0 0 GICv2 222 Level 2490000.ether_qos.rx0 <<<<<<<< No change
38: 10180 0 0 0 0 0 GICv2 218 Level 2490000.ether_qos.tx0 <<<<<<< change with outgoing packets
------ ethtool dump
jetson-tx2-dev:/sys/kernel/debug# ethtool -i eth0
driver: eqos
version:
firmware-version:
expansion-rom-version:
bus-info: 2490000.ether_qos
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
jetson-tx2-dev:/sys/kernel/debug# ethtool -S eth0
NIC statistics:
mmc_tx_octetcount_gb: 14760907
mmc_tx_framecount_gb: 229948
mmc_tx_broadcastframe_g: 7787
mmc_tx_multicastframe_g: 221607
mmc_tx_64_octets_gb: 229353
mmc_tx_65_to_127_octets_gb: 378
mmc_tx_128_to_255_octets_gb: 176
mmc_tx_256_to_511_octets_gb: 36
mmc_tx_512_to_1023_octets_gb: 5
mmc_tx_1024_to_max_octets_gb: 0
mmc_tx_unicast_gb: 554
mmc_tx_multicast_gb: 221607
mmc_tx_broadcast_gb: 7787
mmc_tx_underflow_error: 0
mmc_tx_singlecol_g: 0
mmc_tx_multicol_g: 0
mmc_tx_deferred: 0
mmc_tx_latecol: 0
mmc_tx_exesscol: 0
mmc_tx_carrier_error: 0
mmc_tx_octetcount_g: 14760907
mmc_tx_framecount_g: 229948
mmc_tx_excessdef: 0
mmc_tx_pause_frame: 221561
mmc_tx_vlan_frame_g: 0
mmc_rx_framecount_gb: 17971
mmc_rx_octetcount_gb: 1608718
mmc_rx_octetcount_g: 1608718
mmc_rx_broadcastframe_g: 4837
mmc_rx_multicastframe_g: 5172
mmc_rx_crc_error: 0
mmc_rx_align_error: 0
mmc_rx_run_error: 0
mmc_rx_jabber_error: 0
mmc_rx_undersize_g: 0
mmc_rx_oversize_g: 0
mmc_rx_64_octets_gb: 16360
mmc_rx_65_to_127_octets_gb: 136
mmc_rx_128_to_255_octets_gb: 55
mmc_rx_256_to_511_octets_gb: 1412
mmc_rx_512_to_1023_octets_gb: 2
mmc_rx_1024_to_max_octets_gb: 6
mmc_rx_unicast_g: 7962
mmc_rx_length_error: 0
mmc_rx_outofrangetype: 0
mmc_rx_pause_frames: 0
mmc_rx_fifo_overflow: 17263 <<<<<<<<<<<<< increase with every input packet
mmc_rx_vlan_frames_gb: 0
mmc_rx_watchdog_error: 0
mmc_rx_ipc_intr_mask: 24694931433
mmc_rx_ipc_intr: 0
mmc_rx_ipv4_gd: 1871
mmc_rx_ipv4_hderr: 0
mmc_rx_ipv4_nopay: 0
mmc_rx_ipv4_frag: 0
mmc_rx_ipv4_udsbl: 0
mmc_rx_ipv6_gd_octets: 0
mmc_rx_ipv6_hderr_octets: 0
mmc_rx_ipv6_nopay_octets: 0
mmc_rx_udp_gd: 1734
mmc_rx_udp_err: 0
mmc_rx_tcp_gd: 129
mmc_rx_tcp_err: 0
mmc_rx_icmp_gd: 8
mmc_rx_icmp_err: 0
mmc_rx_ipv4_gd_octets: 543600
mmc_rx_ipv4_hderr_octets: 0
mmc_rx_ipv4_nopay_octets: 0
mmc_rx_ipv4_frag_octets: 0
mmc_rx_ipv4_udsbl_octets: 0
mmc_rx_ipv6_gd: 0
mmc_rx_ipv6_hderr: 0
mmc_rx_ipv6_nopay: 0
mmc_rx_udp_gd_octets: 487097
mmc_rx_udp_err_octets: 0
mmc_rx_tcp_gd_octets: 18571
mmc_rx_tcp_err_octets: 0
mmc_rx_icmp_gd_octets: 512
mmc_rx_icmp_err_octets: 0
q_re_alloc_rx_buf_failed[0]: 0
q_re_alloc_rx_buf_failed[1]: 0
q_re_alloc_rx_buf_failed[2]: 0
q_re_alloc_rx_buf_failed[3]: 0
q_re_alloc_rx_buf_failed[4]: 0
q_re_alloc_rx_buf_failed[5]: 0
q_re_alloc_rx_buf_failed[6]: 0
q_re_alloc_rx_buf_failed[7]: 0
tx_process_stopped_irq_n[0]: 0
tx_process_stopped_irq_n[1]: 0
tx_process_stopped_irq_n[2]: 0
tx_process_stopped_irq_n[3]: 0
tx_process_stopped_irq_n[4]: 0
tx_process_stopped_irq_n[5]: 0
tx_process_stopped_irq_n[6]: 0
tx_process_stopped_irq_n[7]: 0
rx_process_stopped_irq_n[0]: 0
rx_process_stopped_irq_n[1]: 0
rx_process_stopped_irq_n[2]: 0
rx_process_stopped_irq_n[3]: 0
rx_process_stopped_irq_n[4]: 0
rx_process_stopped_irq_n[5]: 0
rx_process_stopped_irq_n[6]: 0
rx_process_stopped_irq_n[7]: 0
tx_buf_unavailable_irq_n[0]: 0
tx_buf_unavailable_irq_n[1]: 0
tx_buf_unavailable_irq_n[2]: 0
tx_buf_unavailable_irq_n[3]: 0
tx_buf_unavailable_irq_n[4]: 0
tx_buf_unavailable_irq_n[5]: 0
tx_buf_unavailable_irq_n[6]: 0
tx_buf_unavailable_irq_n[7]: 0
rx_buf_unavailable_irq_n[0]: 0
rx_buf_unavailable_irq_n[1]: 0
rx_buf_unavailable_irq_n[2]: 0
rx_buf_unavailable_irq_n[3]: 0
rx_buf_unavailable_irq_n[4]: 0
rx_buf_unavailable_irq_n[5]: 0
rx_buf_unavailable_irq_n[6]: 0
rx_buf_unavailable_irq_n[7]: 0
rx_watchdog_irq_n: 0
fatal_bus_error_irq_n: 0
pmt_irq_n: 0
tx_normal_irq_n[0]: 10010
tx_normal_irq_n[1]: 0
tx_normal_irq_n[2]: 0
tx_normal_irq_n[3]: 0
tx_normal_irq_n[4]: 0
tx_normal_irq_n[5]: 0
tx_normal_irq_n[6]: 0
tx_normal_irq_n[7]: 0
rx_normal_irq_n[0]: 3067
rx_normal_irq_n[1]: 0
rx_normal_irq_n[2]: 0
rx_normal_irq_n[3]: 0
rx_normal_irq_n[4]: 0
rx_normal_irq_n[5]: 0
rx_normal_irq_n[6]: 0
rx_normal_irq_n[7]: 0
napi_poll_n: 0
tx_clean_n[0]: 10010
tx_clean_n[1]: 0
tx_clean_n[2]: 0
tx_clean_n[3]: 0
tx_clean_n[4]: 0
tx_clean_n[5]: 0
tx_clean_n[6]: 0
tx_clean_n[7]: 0
tx_path_in_lpi_mode_irq_n: 0
tx_path_exit_lpi_mode_irq_n: 0
rx_path_in_lpi_mode_irq_n: 0
rx_path_exit_lpi_mode_irq_n: 0
tx_pkt_n: 10015
rx_pkt_n: 3147
tx_vlan_pkt_n: 0
rx_vlan_pkt_n: 0
tx_timestamp_captured_n: 0
rx_timestamp_captured_n: 0
tx_tso_pkt_n: 6
q_tx_pkt_n[0]: 10015
q_tx_pkt_n[1]: 0
q_tx_pkt_n[2]: 0
q_tx_pkt_n[3]: 0
q_tx_pkt_n[4]: 0
q_tx_pkt_n[5]: 0
q_tx_pkt_n[6]: 0
q_tx_pkt_n[7]: 0
q_rx_pkt_n[0]: 3147
q_rx_pkt_n[1]: 0
q_rx_pkt_n[2]: 0
q_rx_pkt_n[3]: 0
q_rx_pkt_n[4]: 0
q_rx_pkt_n[5]: 0
q_rx_pkt_n[6]: 0
q_rx_pkt_n[7]: 0
link_disconnect_count: 2
link_connect_count: 8
