Can anyone confirm if the TX2 would be compatible with the Jetson Nano dev kit? The issue I have is that the carrier boards and cases available for the TX2 are more expensive than those for the nano. I would like to use the dev kit from the nano with a TX2 board fitted - is this possible?
Thanks,
