Jetson TX2 NX internal Pull-Up, Pull-Down resistor value?
about Jetson TX2 NX
I want to know Internal Pull-Up, Pull-Down resistor value for all of pins
if Internal Pull-up with External Pull-down, how can i calculate Input Voltage?
What we can provide are all in DLC. You can check module datasheet or pinmux sheet for some info. If it is set to input mode, it should be high-z pin status, the input voltage is the external voltage.
