Error: Cannot get the local file: /opt/nvidia/sdkmanager/Eula/NV_JETPACK_CUDA_EULA.txt
When I use the command line “sdkmanager --cli install --offline --logintype devzone --product Jetson --host --targetos Linux --version 4.6.1 --target JETSON_TX2_TARGETS --additionalsdk DeepStream --select ‘Jetson OS’ --select ‘Jetson SDK Components’ --flash all” to flash the device.
Offline? have CUDA been installed correctly?
You mean the CUDA on host? it has been installed. By the way, how can I flash several Jetson TX2 devices with SDK Manager? Thanks.
