Jetson TX2 PEO support to power the carrier board
does the Jetson TX2 dev kit support POE?
If it doesn’t and we use a PEO splitter, would PEO provide enough power to the board?
note: POE has two standards 802-3af (~12W on device) and 802-3at (~25W on device)?
Thank you
–YB
No, POE is not supported on TX2. For splitter, you can compare its character to module power requests in OEM DG and module datasheet to see if available.
