I am not able to turn on the Board as soon as I connect the adapter it starts blinking with a beep sound.
I checked the connectivity of input DC port and it is short.
How can I further check what has gone wrong with the board?
Any possibility of repair?
Hi, is this on dev kit or your own custom board? Beep sound might be from some big capacitors, you can try removing the caps, ESD components near to DC port one by one.
Hi, thanks for the quick response.
Yes, this is on the Dev kit.
Hi Trumany,
Can you give more details on your advice: “you can try removing the caps, ESD components near to DC port one by one”
I’ve no idea about this, will this make the beep sound go off, or the board will start working after removing the faulty capacitor?
I’d be great if there’s any manual/instructions for troubleshooting this issue.
