HI,
I have a question relevant to VDD_5V0_IO_SYS. Is this voltage need if the jetson is not yet started?
I read that there is a pull-up to VDD_5V0_IO_SYS but I do net see it in my adapter, I start to furnish the 5V when CARR_PWON is set only, than there is no voltage on PWR_BTN. Have I produce this voltage before? and if yes where I have to apply to jetson module?
thank you
maurizio
