Jetson TX2 programming
I AM using the Jetson TX2 as part of a robotics application. Currently I use the Jetpack 3.2.1, specifically the flash utility and the Jetson, devkit board and USB cable to program the TX2. I am creating a manufacturing test for the assembly that is using the TX2 and I would like to automate the programming of the TX2. Is there an API or DLL set for Windows 7/10 64bit that would allow the programming of the TX2 via my test software?
Thanks for your help.
Kind regards,
DS
You could try installing Windows Subsystem for Linux and see if the flashing scripts from Jetpack will work.
However, WSL is not driver-compatible with all Linux devices, so it may not properly expose the USB ports; you’ll have to try it to find out.
If that doesn’t work, then you’ll have to run Linux on the manufacturing system instead of Windows.
