HI,
following the problem relevant to usb1_en,
is there a way to read the jetson gpio status?
thank you
maurizio stefani
HI,
thank you
maurizio stefani
hello progsel.stefani,
you could simply access the device node to read the pin status.
for example,
# enter the location of the GPIOs
cd /sys/class/gpio/
or, you may use the kernel APIs to check the pin state.
for example,
<i>$l4t-r32.2/public_sources/kernel_src/kernel/kernel-4.9/include/linux/gpio.h</i>
static inline int gpio_get_value(unsigned int gpio){...}
static inline void gpio_set_value(unsigned int gpio, int value) {...}
